Any word on Pinephone Pro performance
Just got word my pinephone pro has shipped.  Takes a week or so to get to me.
Anyone with any experiences on pinephone pro that may have already been received:  stability, consistency, sms, mms, gps, etc.
thanks,     tom kosvic
(01-24-2022, 09:00 AM)tckosvic Wrote: Just got word my pinephone pro has shipped.  Takes a week or so to get to me.
thanks,     tom kosvic
I've been using the phone for a few days using KDE Plasma manjaro. Today there is a problem of freezing the lock screen, it is solved by disabling automatic suspend. The autonomy of battery is still at a low level. The speed of work is higher compared to the original pinephone, and today it is comfortable to use the phone (the speed of GUI is at the level of android smartphones for $ 100-150). Calls and sms work, mms did not check. GPS works fine, accuracy is average, cold start is long in time 3-5 minutes. Compared to the original pinephone, this is a Sonic Hedgehog. Ready to answer questions.
  systemic issue pinephone penguins_rule 3 427 04-02-2024, 11:52 AM
  link for supported pinephone os manjharo et all penguins_rule 2 245 03-19-2024, 10:36 AM
Last Post: penguins_rule
  new PinePhone upgrade issue WhiteHexagon 5 1,811 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 2,543 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 7,506 02-04-2023, 08:35 PM
Last Post: Westslope
  Pinephone craches after each call neithan76 2 1,627 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,494 07-28-2022, 12:40 PM
Last Post: johaennessen
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,079 05-09-2022, 08:29 AM
Last Post: ragreenburg
  "Emergency" terminal on pinephone (with default setup) altulke 5 2,695 05-03-2022, 12:42 PM
Last Post: altulke
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 1,899 04-07-2022, 06:02 AM
Last Post: danimations
