Touch Screen monitor/module
Hello. I'm looking to buy a touchscreen monitor/module for a project. However, the official 7in one in the store is too small.
My question basically is, would any type of touch screen monitor work or are there restrictions?
Essentially I want to create a project similar to this but that monitor is quite outdated/hard to find.
Since you would need a matching driver for any other LCD you connect besides the one you can order with the pine, maybe think about a small HDMI display with full HD? Touch input is still another issue then though, maybe something that works via I2C or UART, but I have no experience with that...
I was looking at something like this:
http://www.buydisplay.com/default/10-1-i...d-1024x600
You can look at this https://youtu.be/UtAv_fjB8BE
11.6 inch 1080p with capacitive multitouch. I just tested it with PINE64 and it works perfect without any additional manipulations in Android/Remix. PM me if you interested.
Thanks! PM'd
Question Z-Wave module pinout to make it compatible with Pi b+ ebretteville 59 137,318 07-12-2019, 08:55 AM
Last Post: kris240376
  using Cellphone/mobile phone display screen desai_amogh 9 38,784 12-24-2018, 04:16 AM
Last Post: benhadad
  LCD Screen for running Octoprint sb_88 2 8,618 03-14-2017, 08:40 AM
Last Post: sb_88
  KICAD Quick Lib and Module Generator mbt28 1 7,852 02-12-2017, 10:45 PM
  Portable USB-Powered Monitor mribunal 4 15,530 02-03-2017, 05:28 AM
Last Post: stevenmeza07
  Z Wave Module and still using GPIO bang 2 9,540 01-16-2017, 03:12 AM
Last Post: bang
  Z-Wave US module with adapter aegrotatio 4 12,413 01-08-2017, 12:03 AM
Last Post: aegrotatio
  touch screen not working mike280z 1 5,933 12-22-2016, 12:46 PM
Last Post: Bluphire
  RaZberry Module (z-wave) need support to get it working! Luxus 13 30,877 11-03-2016, 02:04 AM
Last Post: Luxus
  Z-Wave module problem vintagewaffle 0 3,857 10-26-2016, 10:50 AM
Last Post: vintagewaffle
