Z-Wave US module with adapter
I have the Z-Wave US module that plugs into an adapter that plugs into the Pi-2 bus.
This is probably answered somewhere but my searches are saturated with irrelevant Z-Wave EU information and I'm lost.  How do I use the US module?  Is it hanging off a serial port?  What software can I use to get it working?
Thanks.
(01-03-2017, 10:42 PM)aegrotatio Wrote: I have the Z-Wave US module that plugs into an adapter that plugs into the Pi-2 bus.
Thanks.
Yes, the Z-Wave module is accessed via uart(2)  /dev/ttyS2   (  it is a serial device  )
You can talk to the module via serial protocol manually,  and you can use a serial software package to talk to the module ( point the software at /dev/ttyS2 )
( /dev/ttyS2   uart(2) is on the PI bus )
notes:
Z-Wave Public Specification
OpenHab is probably the best way to get Z-Wave running on the pine board.
Excellent, thanks.
I got it working using the special "OpenHAB" image for PINE A64 and it works fine now.  I would have liked to get the Z-Wave module working with a more generic image distribution, but too many JNI object files were compiled for 32-bit ARM instead of 64-bit ARM and I lost interest in trying to find the source code and recompile them for 64-bit ARM.
Thanks again!!
Question Z-Wave module pinout to make it compatible with Pi b+ ebretteville 59 106,622 07-12-2019, 08:55 AM
Last Post: kris240376
Sad Z-Wave and openzwave+node-openzwave-shared saro 2 7,546 09-01-2017, 05:22 AM
Last Post: saro
  Z-Wave - Full and Low Power Inclusion mode B34N 1 5,285 03-26-2017, 06:03 PM
Last Post: B34N
  KICAD Quick Lib and Module Generator mbt28 1 5,728 02-12-2017, 10:45 PM
  Z Wave Module and still using GPIO bang 2 7,065 01-16-2017, 03:12 AM
Last Post: bang
  TP-Link Archer T1U AC450 Wireless Nano USB Adapter DARK-SPIRIT 0 2,689 11-18-2016, 11:56 AM
Last Post: DARK-SPIRIT
  RaZberry Module (z-wave) need support to get it working! Luxus 13 23,871 11-03-2016, 02:04 AM
Last Post: Luxus
  Z-Wave module problem vintagewaffle 0 2,925 10-26-2016, 10:50 AM
Last Post: vintagewaffle
Video Australia/New Zealand Z-Wave module Jnimmo 46 71,182 10-02-2016, 02:25 PM
  [EU] Z-Wave module tutorials? meowbot 2 6,542 09-13-2016, 07:54 PM
Last Post: Ghost
