LCD Screen for running Octoprint
Hey!
I'm planning to install Octoprint on my pine but not sure about the LCD screen. Based on my quick search, it's possible to install Octoprint on the pine but the LCD touch screen only works with Android. Can anyone point me in the right direction here?
Thanks!
No, the LCD screen works on linux also. Luke is probably the most up to date on that as I haven't been following the LCD stuff of late. However, I believe it is simply a matter of changing a configuration value in the /boot/uEnv.txt file on the Armbian Ubuntu and debian releases.
Why did you want the LCD in this case... did you want to be able to run a web browser so you can see the octoprint dashboard from the machine that is running it? Just that is more common to see a octoprint box running completely headless, and connecting in from another device over the network.
I understand, thanks!
I don't have an LCD screen on my printer to control it directly and I was hoping adding this screen would make it easier for me or someone else using the printer to control it.
  using Cellphone/mobile phone display screen desai_amogh 9 38,656 12-24-2018, 04:16 AM
Last Post: benhadad
  touch screen not working mike280z 1 5,895 12-22-2016, 12:46 PM
Last Post: Bluphire
  LCD screen problem; borahan 4 11,069 09-27-2016, 07:16 PM
Last Post: dkryder
  output on LCD screen Rigor_M 1 5,470 07-18-2016, 12:41 PM
Last Post: Rigor_M
  dead LCD screen? jdmwrx94 0 3,830 07-16-2016, 01:43 PM
Last Post: jdmwrx94
  Touch Screen monitor/module riahim 4 10,850 07-06-2016, 08:07 AM
Last Post: riahim
  How to install Touch Screen? firelegend 1 5,990 06-15-2016, 08:51 PM
Last Post: janjwerner
  512 and 7" touch screen? ShreddinPB 4 10,506 06-15-2016, 08:55 AM
Last Post: ShreddinPB
  Is it possible to have more than one screen? MostHated 2 7,594 03-02-2016, 03:42 PM
Last Post: MostHated
