Megapixels - Camera App - Works w. Beta NOT Pro
The MegaPixel app won't come up using the PPPro.   It does activate on the PPBeta.
I'm using Manjaro/Phosh Dev on both and update daily.
Appears to not be working on Arch either... had been working around 2 weeks ago
The version of Megapixels that Manjaro ships for the PPP is working (but the image quality is still bad, since there is no post-processing. Any picture i've taken so far had to be processed in darktable to get some color accuracy and contrast). Since i'm on Mobian i just downloaded the latest Manjaro-ppp image and mounted it to copy the config and binaries over to my ppp.
For myself, with daily updates from the unstable branch of Manjaro Plasma, the megapixels-ppp package must be installed in order to replace the megapixels package.
$ sudo pacman -S megapixels-ppp
But this is not sufficient at the moment. The device tree seems to need work.
  Upgrading from Trixie to Forky in late 2025(proposal)(tested works for me) biketool 5 4,936 10-28-2025, 03:31 PM
  the camera apps does not work on arch linux sxmo moriartyo 0 1,982 04-21-2025, 03:08 AM
Last Post: moriartyo
  Back/World camera working after suspend DrYak 10 9,229 11-04-2024, 09:41 AM
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 4,582 10-28-2024, 10:46 AM
Last Post: Jite
  Booting from SD Works for Installers, not OS's ?? Diagon 3 4,232 08-13-2023, 03:27 AM
Last Post: fxc
  Manjaro as shipped & camera? hambonius 1 2,811 06-20-2023, 02:26 PM
Last Post: fxc
  Megapixels tuning mburns 18 18,325 03-18-2023, 07:26 AM
Last Post: mburns
  Megapixels on kernel > 5.19? timonoj 1 3,142 01-30-2023, 05:36 PM
Last Post: Piotr
  Megapixels (kernel 5.19) reports that a config file is missing. grump_fiddle_reinstall 2 4,355 11-30-2022, 07:44 AM
Last Post: mburns
  PinePhone Pro Manjaro Plasma Mobile Beta 13 & No Audio with Phone Calls X0X0X0X0X0 0 2,404 11-02-2022, 02:09 PM
Last Post: X0X0X0X0X0
