Back/World camera working after suspend
Some people might be affected by some driver bug where the camera:
  • does works right after boot of the PinePhone Pro.
  • But after suspend, the camera stops working.
e.g.: that's the case when using application Shutter on SailfishOS.
The following trick forces reinitialising the hardware (as if the kernel is populating from device tree during a boot):
echo ff920000.isp1 | sudo tee /sys/bus/platform/drivers/rkisp1/{unbind,bind}
(11-13-2023, 11:01 AM)DrYak Wrote: Some people might be affected by some driver bug where the camera:
Thank you.
I added script
/lib/systemd/system-sleep/90-restore-cam.sleep
on mobian. It seems to work well.
#!/bin/sh
PATH=/sbin:/usr/sbin:/bin:/usr/bin
case "$1" in
    pre)
        #code execution BEFORE sleeping/hibernating/suspending
    post)
        #code execution AFTER resuming
        echo ff920000.isp1 > /sys/bus/platform/drivers/rkisp1/unbind
        echo ff920000.isp1 > /sys/bus/platform/drivers/rkisp1/bind
esac
exit 0
(11-14-2023, 02:25 AM)u-kidjp Wrote: I added script
That's a very cool solution! ?
(Sadly in the case of SailfishOS that doesn't work. Apparently the solution for suspend used there doesn't run those scripts Undecided ).
@megous : Is there a way that you could do this in a "cannocial" way in the driver code ?
  Manjaro as shipped & camera? hambonius 1 912 06-20-2023, 02:26 PM
Last Post: fxc
  Netfilter not working on latest manjaro kernel robocone 1 1,199 12-29-2022, 09:11 PM
Last Post: robocone
  Megapixels - Camera App - Works w. Beta NOT Pro iwm 3 2,968 11-01-2022, 02:13 PM
Last Post: mburns
  Monjaro Plasma Cell Network and Data not working properly maiyuzhe 2 1,598 09-24-2022, 12:15 AM
Last Post: maiyuzhe
  Suspend audio issue kmsgli 4 2,961 08-03-2022, 04:11 PM
Last Post: Subsentient
  Manjaro 5.17.5-1 Keyboard stopped working Yst 7 3,950 06-09-2022, 11:12 AM
Last Post: graphicpanda444
  Plasma Mobile navigation bar scaling is not working Yst 0 841 05-09-2022, 05:10 AM
Last Post: Yst
  Modem turns off on suspend twzorek95 5 3,199 05-06-2022, 01:51 PM
Last Post: ertizpau
  Convergence Working on PPP? joshndroid 3 2,471 04-27-2022, 01:30 PM
Last Post: TheBlindEarthican
  tow-boot: suspend stopped working maltee 3 2,236 03-30-2022, 10:43 AM
Last Post: brb78
