RAM deficiency after recent large Manjaro update?
A couple days ago there was a major-ish Manjaro update. Since then, half of my Chromium tabs and extensions are constantly crashing. I use quite a bit but this wasn't happening before.
$ cat /sys/block/zram0/disksize
6075875328
This means 6 Gigs right? Don't get what the problem is
# swapon /dev/zram0
says it's already busy.
I am using Manjaro without zram, and I have not had any problems with the new update.
  Manjaro Sway Theme Broken Eighty8 1 303 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 343 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,782 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 355 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,183 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,268 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 426 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 919 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,032 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,999 08-21-2023, 09:08 PM
