Mounting / unmounting drives from the Index app (Plasma)
I opened an encrypted SD card using a USB card reader connected to the phone. It appeared in the Index app, which showed the "mount" button and then I could enter the passphrase. But now I don't know how to unmount & lock it. The Index app doesn't have the usual unmounting icon like Dolphin has. I had to unmount via the terminal.
Is there a direct way to unmount & lock a card via the Index app? Or in Settings, or somewhere else?
(10-01-2021, 10:36 AM)theResonant Wrote: Is there a direct way to unmount & lock a card via the Index app?
In Index "long touch" on the SD card and select "Remove".
At least it worked that way here with combo usbA/usbC "memory stick". Nonencrypted media used though...
Selecting "Remove" makes the entry disappear from the sidebar, but if I close Index and re-open it, the card appears again in the sidebar. Also, my card reader has an LED that shows "disconnected" when ejected from the computer, but this doesn't happen when selecting "Remove".
The only way I can trigger a real unmounting is via the terminal. So the "Remove" option is there, but doesn't seem to do much else apart from visually removing the entry. Maybe you're right, it does work for unencrypted media. Will try.
(10-06-2021, 01:29 AM)theResonant Wrote: Selecting "Remove" makes the entry disappear from the sidebar, but if I close Index and re-open it, the card appears again in the sidebar.
Just rechecked and yes, you seems to be right. The USB "stick" after "Remove" and at Index next start is still there and seems to be mounted. At least it does not ask permission to mount it as it happens after the first connection...
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,670 10-02-2023, 05:07 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,880 03-02-2023, 07:25 PM
  Manjaro plasma-mobile Beta 13 Uturn 13 4,996 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,606 11-22-2022, 05:00 PM
Last Post: Chief
  Disabling screen timeout for plasma mobile rp3 7 7,295 09-05-2022, 03:50 PM
Last Post: christev1
  VPN on Plasma Hobgoblin 1 1,311 08-29-2022, 03:14 AM
Last Post: saddamus
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,788 07-28-2022, 12:40 PM
Last Post: johaennessen
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 1,011 07-04-2022, 11:42 AM
Last Post: tuxmain
  double tap to wake > plasma mobile Uturn 3 2,407 05-19-2022, 07:55 PM
Last Post: epiii2
  auto start waydroid in plasma mobile? Uturn 2 2,475 04-19-2022, 03:47 AM
Last Post: dorthatapia
