Manjaro - Internet connection sharing requires dnsmasq (but the dep isn't declared)
Attaching a Rockpro64 via its ethernet port to my PBP, it's supposed to be possible to "share" the PBP's wifi connection with it, which actually involves setting up NAT & DHCP automatically under the hood.
Network Manager > Edit Connections > Wired connection 1 > IPv4 Settings > Method: Shared to other computers
But it didn't work.
After banging on it all morning, I found this article,
https://fedoramagazine.org/internet-conn...rkmanager/
which mentions that it uses dnsmasq. Check; dnsmasq is not running. Check; package dnsmasq is not installed. Install dnsmasq; now it works.
That ought to be declared as a dependency.
Edit: When installing NetworkManager, it does list dnsmasq as an optional dependency for connection sharing. But the user doesn't necessarily ever see this message. It should either be a hard dep, or Network Manager should detect the absence of dnsmasq & give an informative error message, rather than just mysteriously not working.
  Manjaro Sway Theme Broken Eighty8 1 279 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,751 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 328 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,139 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,212 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 406 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 890 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,019 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,969 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 765 08-18-2023, 02:06 AM
Last Post: juliamenendez
