KDE Connect on PinePhone
Hi folks -
I have been trying to use KDE Connect on the PinePhone and not having much success under either Manjaro or Mobian.
 - Software runs, connects to my desktop
 - Desktop recognizes that it is connected to the phone
 - Dolphin will not find the phone to exchange files
 - However, I can send files individually from phone to desktop downloads folder.
I know that using KDE Connect with an Android phone, there is a setting in the "device plug-ins" category that allows you to choose folders to share, but the same menu entry does not have such a capability on the PinePhone.
Anyhow, if anyone has an insight on this issue, I would love to hear it!
Tim
Lucko666
"Just say Angry to smilies.
Remember you're running the desktop end of kdeconnect on the pinephone, not the android app end, so the capabilities are a bit more limited. When I tried it a while back it seemed to do what I'd expect from desktop-to-desktop connections. but I may have missed something. There may also be limitations from running under phosh - I don't know if they've implemented enough gnome shell compatibility to run gsconnect yet, which ought to be a better fit.
There's an outstanding issue tracker for implementing the missing functionality in plasma-mobile, but that won't be much use in phosh due to the different telephony and PIM backends.
https://phabricator.kde.org/T8968
Good point about it being a desktop version on the PinePhone, I had actually realized that yesterday. I guess for now, the file sharing aspect will do what I needed - the occasional back and forth of files - and using Jumpdrive allows big moves when needed. I am using the plasma-mobile OS now day to day so will check out the bug-tracker issue you mention.
Lucko666
  systemic issue pinephone penguins_rule 3 477 04-02-2024, 11:52 AM
  link for supported pinephone os manjharo et all penguins_rule 2 279 03-19-2024, 10:36 AM
Last Post: penguins_rule
  new PinePhone upgrade issue WhiteHexagon 5 1,856 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 2,598 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 7,657 02-04-2023, 08:35 PM
Last Post: Westslope
  Pinephone craches after each call neithan76 2 1,649 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,818 07-28-2022, 12:40 PM
Last Post: johaennessen
  how to connect calindori to nextcloud? Uturn 2 2,358 06-26-2022, 02:09 AM
Last Post: wibble
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,114 05-09-2022, 08:29 AM
Last Post: ragreenburg
  "Emergency" terminal on pinephone (with default setup) altulke 5 2,733 05-03-2022, 12:42 PM
Last Post: altulke
