Pinetime not charging/switching on anymore
I have a dev version of the PineTime and after not using it for some time it is not switching on anymore. Maybe it is not charging either.
Are there any things I can try before buying another one?
Thank you in advance
If you are 100% sure it is fully connected to the charger (those springs on the back of the case are relatively strong and one can lift the back away from the other if you are using a tape or a weak glue) then the next step would be to check the battery and regulator voltages with a multimeter.
Battery is easy since the pads are pretty obvious (expect ~3.7v), you can check the regulator voltage by testing the GND and 3V3 from the SWD connector (see https://wiki.pine64.org/wiki/PineTime_Devkit_Wiring ).
(09-03-2021, 05:16 AM)danielt Wrote: If you are 100% sure it is fully connected to the charger (those springs on the back of the case are relatively strong and one can lift the back away from the other if you are using a tape or a weak glue) then the next step would be to check the battery and regulator voltages with a multimeter.
Battery looks to be dead, I am measuring only 0.6v from them.
That doesn't sound great. Certainly sounds like something is broken.
Only other interesting experiment I can think of is to see if the battery (or 5v supply) voltage changes when 5v is applied to the charging pads (e.g. does the charger circuit work or has the battery failed) however it can physically tricky since it's only an easy test if you possess four hands.
An easier, but destructive, alternative might be to desolder one of the battery leads and see if the screen can fire up with the battery disconnected. That would prove whether the problem is battery or charger (and if it is the battery then you do, at least, have a battery-less watch to use as a development/test device if you want to).
  PineTime at FOSDEM jmlich 5 950 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 304 01-31-2024, 11:57 AM
Last Post: tynstar
  PineTime and Amazfish on Ubuntu Touch jmlich 1 826 10-14-2023, 04:12 PM
  PineTime is dead!! Markdanni123 12 14,174 09-18-2023, 10:17 PM
Last Post: ccchan234
  PineTime Sleep Tracking any_mouse 12 12,738 07-10-2023, 05:41 PM
Last Post: davidair
  PineTime Dead out of box? henkery 1 1,297 03-12-2023, 04:34 PM
Last Post: henkery
  Pinetime almost dead... only shows Infinitime logo. lightweight 8 7,056 02-11-2023, 09:30 AM
Last Post: alexmitroff
  Watchmate doesn't connect to PT anymore jojuma 1 1,430 02-07-2023, 02:43 AM
Last Post: azymohliad
  PineTime beginner MV1791 2 2,275 01-09-2023, 11:52 PM
Last Post: Canyonless
  Struggling to detect Pinetime over bluetooth John45595 0 1,201 11-20-2022, 11:06 PM
Last Post: John45595
