Anyone tried Signal Desktop
(09-14-2021, 10:27 AM)godzillest Wrote:
(09-03-2021, 06:04 PM)jmcsys Wrote: I just tested the latest release. https://git.omniteck.com/
version 5.15
It works, sluggish like everything else on the pinephone, but at least its working.
Calls over signal have about a 1.5 second delay, but text and pictures are working and thats mainly what I need it for.
The latest 5.17 installs and starts up, but never gets past the initial loading icon (I'm running mobian bookworm). I can't find older .deb packages and I'm not skilled with building from scratch. Would you happen to have the old .deb?
What you need to do is click on the dropdown menu thing that shows "Master" and go to "Tags" and it will show the other version of the releases. Below is a 5.16 release.
https://github.com/0mniteck/Signal-Deskt...ds/release
For what it's worth, I haven't been able to get mine to sync with Axolotl so don't get your hopes too high. I've tried 5 times or so to get it to work but it just hasn't. If you do get it to work let me know though!
Can binaries from https://omniteck.com/ be trusted? omniteck is a "security researcher" that does not seem to be active on any pine forum or chat community. People can't post issues on his github. No reproducible verifiable build. You can not prove your compiled binary from his source is the same one on github. What good is a self signed deb if the author can't be trusted? Long time community contributor undef1 also releases signal-desktop builds and is active in the community. https://gitlab.com/undef1/signal-desktop...-/packages with out the theater of a self signed deb. Signal has added Apple M1 ARM support in v5.27.1. https://github.com/signalapp/Signal-Desktop/releases The community should push the signal foundation to release an official ARM64 deb.
(01-14-2022, 03:51 PM)vusra Wrote: Can  binaries from https://omniteck.com/ be trusted?  omniteck  is a "security researcher"  that does not seem to be active on any pine forum or  chat community.  People can't post issues on his github.  No reproducible verifiable build. You can not prove your compiled binary from his source is the same one on github.  What good is a self signed deb if the author can't be trusted?  Long time community contributor undef1  also releases signal-desktop builds and is active in the community. https://gitlab.com/undef1/signal-desktop...-/packages  with out the theater of a self signed deb.    Signal has added Apple M1 ARM support in v5.27.1. https://github.com/signalapp/Signal-Desktop/releases  The community should push the signal foundation to release an official ARM64 deb.
+1 for undef's repo.
I tried out Signal 5.28 beta this morning (https://gitlab.com/undef1/signal-desktop...-/packages - which includes a collapse-able left menu pane: https://github.com/signalapp/Signal-Desktop/issues/2454) having sync'ed to my primary phone and it's not half bad to use.
Omniteck used to publish the corresponding scripts with the deb file but I've stopped considering it a viable option as soon as only deb files were being published. It's sketchy enough using a third-party to install Signal, let alone one that doesn't allow you to see the build process.
omnitek could be a good guy. Our community should not discourage contributors. He would probably welcome help to make his work more trustworthy. We should not offend contributors to our small community. Aren't his scripts still published? https://github.com/0mniteck/Signal-Desktop-Builder
(01-14-2022, 04:05 PM)Korac Wrote: +1 for undef's repo.
Did you use the bullseye tar? Does beta mean undef1 repo follows the signal-desktop's beta releases?
They absolutely could be!
At the point I last reviewed the project, it appeared to be missing some source (It looks like it has since been updated?) that I thought should have been included. Considering that users expect Signal to be secure and without prying eyes, obscuring any part of the project (whether intentionally or accidentally) is a reasonable and valid criticism. I don't intend to put down the author for their contributions.
Re: undef's repo. I'm running bookworm so I used the non-bullseye release. undef appears to follow a similar release pattern to Signal. Hopefully they release a stable version soon (since they've only released beta releases so far).
Is this build based on  https://github.com/signalapp/Signal-Desk...8.0-beta.1 ?    If you click Help   then About Signal Desktop  does it say production or beta?
Appologies for resurfacing this "old" thread, but I was looking into this issue again to see if the Signal Foundation has made any progress.
As I had an open feature request on their Community page since August 2019 (https://community.signalusers.org/t/sign...64/9001/34).
And the only "trustworthy" source for a Signal Client outside the Foundation I think is the one released by Dennis Ameling (https://github.com/dennisameling/Signal-Desktop) as he works closely with the developers of the Foundation and has their blessing and his stuff gets merged into the official repos too.
Only downside for now is that he only works on the Desktop Client.
Using github ( https://github.com/signalapp/Signal-Desktop/issues/3410 ) will reach more developers than the community forum. A proof of concept arm64 debian build from dennisameling was released https://github.com/dennisameling/Signal-...-arm64-poc . Newer dennisameling builds are for arm64 windows only.
I had hoped for support from the foundation, to build a native client for the pinephone.
The lack of Signal, is the reason i have "binned" my PP , and bought an iPhone
Too bad ... I had hoped for an alternative to Android/IOS
/Bingo
(05-22-2022, 04:34 AM)bingo600 Wrote: I had hoped for support from the foundation, to build a native client for the pinephone.
/Bingo
Axolotl exists which is a signal client that works for the Pinephone.
  signal for pinefon wigan 2 296 03-25-2024, 09:25 AM
Last Post: Pavlos1
  Has anyone got briar-desktop running on mobian? vusra 5 3,036 06-19-2023, 03:02 PM
Last Post: vusra
  Sending Pinephone SMS from Desktop biketool 5 2,947 09-13-2022, 01:46 PM
Last Post: anonymous
  Telegram and Signal Zebulon Walton 12 14,784 09-06-2022, 02:02 PM
Last Post: arno_nuehm
  Telegram not as desktop app user641 0 795 08-05-2022, 08:45 AM
Last Post: user641
  Software update missing on desktop MikeMan 1 1,459 01-27-2022, 06:10 AM
Last Post: bcnaz
  Changing Desktop Environments? Ferriah 14 8,618 01-20-2022, 06:58 AM
  Synchronizing: How do you sync / synchronize Calendar and Contacts with your desktop? Anna 15 14,290 11-04-2021, 03:54 AM
Last Post: Maus
  request desktop site from Firefox-esr? nelstomlinson 2 2,284 08-16-2021, 07:23 AM
Last Post: nelstomlinson
  Remote desktop, video playback issues Zebulon Walton 13 10,982 06-17-2021, 06:57 AM
Last Post: aus
