signal for pinefon
o Signal for Pinefon is 'signal-desktop_6.44.1_arm64.deb' at Gitlab (Requires
  Signal on your android)...
    - https://gitlab.com/undef1/signal-desktop...s/22135879
Download both files (?.deb and ?.deb.sig) in same dir. Click on the ^ next
to the getlab .deb file and get the check sum. Go to that download dir and
check signature w/...
>sha256sum signal-desktop_6.44.1_arm64.deb
Output: long number
Check long number against the check sum
o  Install...
      >dpkg -i signal-desktop_6.44.1_arm64.deb
-wigan-
(02-17-2024, 03:37 PM)wigan Wrote: o Signal for Pinefon is 'signal-desktop_6.44.1_arm64.deb' at Gitlab (Requires
      >sha256sum signal-desktop_6.44.1_arm64.deb
      Output:  long number
o  Install...
-wigan-
What can you do when you don't have an Android device?
      Output:  long number
o  Install...
-wigan-
You can give axolotl a try: https://github.com/nanu-c/axolotl
  Telegram and Signal Zebulon Walton 12 14,793 09-06-2022, 02:02 PM
Last Post: arno_nuehm
  Anyone tried Signal Desktop ragreenburg 20 14,308 05-23-2022, 04:41 AM
Last Post: Anna
