Has anyone got briar-desktop running on mobian?
Has anyone got  briar-desktop running on mobian? https://code.briarproject.org/briar/briar-desktop
https://briarproject.org/how-it-works/ Briar  is a decentralized  peer to peer  messenger.   Please share your arm64 build instructions.
Update.
Brair project is now releasing an arm64 nightly-build tar. Not touch friendly. https://code.briarproject.org/briar/bria..._linux_arm
(01-17-2022, 01:49 AM)vusra Wrote: Has anyone got  briar-desktop running on mobian? https://code.briarproject.org/briar/briar-desktop
Have you tried to run it? I hope that it works. Otherwise, maybe try Jami.
I tried it (building myself, with java and flatpak), but did not succeed. I use Jami for now, the flatpak works fine.
Exclamation
Maybe I can help you. How did it fail? Was a library missing from the classpath? Did javac succeed in compiling? Which version of OpenJDK did you use?
Those build instructions should work:
https://code.briarproject.org/briar/bria...nd-running
If you just want to run it without building it, use the following command lines:
sudo apt install openjdk-17-jre
wget https://code.briarproject.org/briar/briar-desktop/-/jobs/artifacts/main/raw/briar-desktop.jar?job=b_jar
java -jar 'briar-desktop.jar?job=b_jar'
N.B: It doesn't work yet, libskiko is missing, it's a dependency of the Compose UI framework used in Briar Desktop:
Quote:Cannot find libskiko-linux-arm64.so.sha256, proper native dependency missing
Actually, libskiko-linux-arm64.so.sha256 and libskiko-linux-arm64.so are missing from the JAR. It's a known bug. You can find the missing files here in the latest release of skiko, look for skiko-awt-runtime-linux-arm64.jar. Adding the missing files into the nightly build is enough to make it work.
Thanks, I will try it in a few weeks. Smile
briar-desktop arm64 nightly-build tar https://code.briarproject.org/briar/bria..._linux_arm
  Mobian repository status henrythemouse 16 8,724 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,988 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 128 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,986 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,803 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 632 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,875 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,893 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 628 07-05-2023, 03:57 AM
Last Post: paulcarton
  Axolotl on PinePhone / Mobian arno_nuehm 219 165,246 03-26-2023, 01:49 AM
Last Post: shulamy
