request desktop site from Firefox-esr?
Is there a way to have Firefox get the desktop version rather than the mobile version? I pretty much never want to see the mobile version.
Pinephone beta edition, convergence model, Mobian Bookworm with Phosh.
You can change general.useragent.override in about:config and pretend to be anything you want. If you remove the part "Android 9; Mobile;" from the general.useragent.override variable most, if not all sites will show the desktop variant. There are some add-ons that allow you to switch the user agent quickly or you can use second profile to have a 'desktop'-firefox and a 'mobile'-firefox.
(08-15-2021, 10:53 AM)IVp Wrote: You can change general.useragent.override in about:config and pretend to be anything you want. If you remove the part "Android 9; Mobile;" from the general.useragent.override variable most, if not all sites will show the desktop variant. There are some add-ons that allow you to switch the user agent quickly or you can use second profile to have a 'desktop'-firefox and a 'mobile'-firefox.
Thanks! that did it. I had been trying to download and install a user agent switcher, but when I pushed the download file button, I would get a popup with a cancel button and an add button, and neither would do anything. Good thing firefox is usable without add-ons
  Why is Firefox ESR not listet under "Installed" in "Software" jojuma 0 594 08-30-2023, 03:23 PM
Last Post: jojuma
  Has anyone got briar-desktop running on mobian? vusra 5 3,031 06-19-2023, 03:02 PM
Last Post: vusra
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 1,792 02-24-2023, 12:11 AM
Last Post: nexion
Exclamation The webcam doesn't work in Firefox anonymous 0 736 11-06-2022, 01:45 PM
Last Post: anonymous
  Sending Pinephone SMS from Desktop biketool 5 2,945 09-13-2022, 01:46 PM
  Telegram not as desktop app user641 0 792 08-05-2022, 08:45 AM
Last Post: user641
  How to move Firefox address bar back to top? Zebulon Walton 5 2,986 06-11-2022, 09:41 AM
Last Post: iwakura_lain
  Anyone tried Signal Desktop ragreenburg 20 14,280 05-23-2022, 04:41 AM
Last Post: Anna
  Firefox browser tweaks biketool 4 3,069 03-11-2022, 04:14 AM
  Software update missing on desktop MikeMan 1 1,458 01-27-2022, 06:10 AM
Last Post: bcnaz
