PineTime suitable for wake-up alarms?
Hey all,
Playing with the thought to buy one, I wondered whether the PineTime is currently capable of waking you up via vibration -- presumably by notifying you about an alarm going off on your smartphone over a companion app, as this thread states an alarm app is to be developed.
Planning to use a PineTime with InfiniTime and Gadgetbridge as companion app, but did only find implicit statements for and against said capability.
Grateful for any answer Smile
Cheers
Currently, there's a couple of issues. Firstly, using GadgetBridge+Pinetime+Infinitime, the connection seems to drop quite frequently, requiring a restart of the PineTime before it can reconnect. Because of this, the chances of missing the alarm are high. Second, in my experience, when an alarm does go off, the Pinetime (with infinitime) only vibrates once, no matter how long the alarm is going off. A single vibration on your wrist with no sound, is not going to reliably wake many people up.
Hopefully later versions of Infinitime will work on both reliability of the bluetooth connection and also vibrating continually until dismissed (either on the watch or phone). When that happens it's likely to be a good option. Until then I'd suggest sticking with your phone near your bead. ;P
Yes, but only using Wasp OS currently. I use the pinetime to wake me every morning. The alarm in Wasp OS vibrates extremely energetically many times and has never failed to wake me.
Unfortunately battery life of Wasp OS is a lot shorter than that of infinitime, so the pinetime needs to be recharged every two days or so.
  PineTime at FOSDEM jmlich 5 922 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 289 01-31-2024, 11:57 AM
Last Post: tynstar
  PineTime and Amazfish on Ubuntu Touch jmlich 1 808 10-14-2023, 04:12 PM
  PineTime is dead!! Markdanni123 12 14,144 09-18-2023, 10:17 PM
Last Post: ccchan234
  PineTime Sleep Tracking any_mouse 12 12,691 07-10-2023, 05:41 PM
Last Post: davidair
  PineTime Dead out of box? henkery 1 1,283 03-12-2023, 04:34 PM
Last Post: henkery
  Pinetime almost dead... only shows Infinitime logo. lightweight 8 7,017 02-11-2023, 09:30 AM
Last Post: alexmitroff
  PineTime beginner MV1791 2 2,270 01-09-2023, 11:52 PM
Last Post: Canyonless
  Struggling to detect Pinetime over bluetooth John45595 0 1,199 11-20-2022, 11:06 PM
Last Post: John45595
  PineTime Dev Kit for sale igor.bljahhin 2 3,271 10-19-2022, 05:34 AM
Last Post: peatord
