Did I brick my RockPro64 somehow?
I had a RockPro64 running on microSD just fine and forgot it was still turned on and tried to connect the eMMC to it. After popping out the microSD I noticed it wasn't booting on eMMC so plugged back in the microSD, however it no longer seems to boot fully on microSD anymore as well (e.g. my keyboard LEDs don't flash, no video output detected to TV).
Is it possible to brick the RockPro64 somehow by connecting a flashed eMMC while actively running off of microSD?
(07-19-2021, 07:56 PM)snarfel Wrote: ...
I guess anything is possible - a very much uncontrolled situation. Although conceivably the eMMC is a removable media and so theoretically it shouldn't be a problem.
(07-19-2021, 07:56 PM)snarfel Wrote: ... it no longer seems to boot fully on microSD anymore ...
Does there seem to be some boot activity (onboard LEDs light etc)?
Perhaps the filesystem on the SDcard is (co-incidentally) corrupt?
PS - if you have left the eMMC connected then of course the boot priority is eMMC first then SDcard unless you do the secret jumper trick
  RockPro64 automatically run after power recovery - my solution g2t 1 944 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 3,834 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,281 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 4,838 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 4,193 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 5,517 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,383 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 12,657 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 4,716 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 5,901 04-06-2023, 02:46 PM
