Pinebook Pro Docking Deck Seems to be DOA
I received my Dock today, but it seems that it doesn't function properly, none of the ports are working including the VGA and HDMI. When I plug the dock into the laptop's type c port, I get a loud coil whine. This also happens if I plug power into the dock's power port. Has anybody else experienced similar issues? your help would be greatly appreciated.
I got 2 docks, as I have 2 Pinebook pros. One dock works fine, the other is very inconsistent with and usually does not provide Ethernet. I think the one is just not made well, but discovered outside the 30 day warranty.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 533 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 332 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 277 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 610 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,079 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,075 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,003 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,414 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 135,474 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,889 10-21-2022, 07:57 AM
Last Post: dachalife
