Manjaro wont recognize eMMC after booting with it disabled
I tried to install Manjaro on the eMMC on my PBP but didn't know that using the "erase" option to make a new partition table would leave the system broken.  To get the machine to turn on, I have to disable the eMMC with the hardware switch so that it will boot off the SD card.  I want to try the installation on the eMMC again, but after booting from SD card (flashed with the Manjaro xfce image from the manjaro site) with the eMMC switch off and then turning the eMMC switch back on, I still can't access the drive.  I tried running (as root):
echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/unbind
but it fails with "No such device".
Any advice would be appreciated!
The actual path to the device is kernel dependent. So, try finding the proper device name first:
<code>find /sys -name "sdhci"</code>
And if you find what appears to be a suitable entry, check to see if their is a "unbind" and "bind" in that directory.
Further, I don't know if the actual device path of "fe330000.sdhci" would still apply...
Arwen Evenstar
Princess of Rivendale
  Manjaro Sway Theme Broken Eighty8 1 278 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,749 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 327 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,136 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,207 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 406 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 887 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,018 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,967 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 765 08-18-2023, 02:06 AM
Last Post: juliamenendez
