Hardware video acceleration in Chromium on Manjaro
Lightbulb
Earlier today, when i was bored, I turned on "Hardware-accelerated video decode" and "GPU rasterization" in Chromium browser ( chrome://flags ). To my surprise, it actually worked well, bringing CPU load to 80% when playing plain H.264, compared to 160% before.
I am currently Manjaro 21.05 with GNOME 40 on my Pinebook Pro.
I wonder if it works "just for me", so you guys might give it a try.
The relative change in performance seems quite good, on the other hand 80% of a single core to play a video does not really sound like fully working acceleration.
Did you check which of these two options caused the improvement? What test or website did you use?
Is it really hardware accelerated?
Open the devtools with F12 and open the `media` tab. (it's in the hamburger menu under "More Tools" if you've never opened it before)
It will tell you if it's hardware accel'd. For me it shows FFmpegVideoDecoder, which is software. I think MojoVideoDecoder would be hardware.
(05-31-2021, 07:14 AM)maxjrh Wrote: Is it really hardware accelerated?
I'm a little embarrassed, but you are right. I am seeing "FFmpegVideoDecoder" as well. Turning HW acceleration off and on running with different test videos and formats actually show no effect in CPU usage.
What I observed with my first test was a mere coincidence and I got all exited over it and posted prematurely ;-)
And also Chromium would happily lie about HW Video acceleration in chrome://gpu
"Boosted" my PBP with a load of Placebo.
  Manjaro Sway Theme Broken Eighty8 1 280 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,754 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 328 01-19-2024, 11:32 PM
  Streaming video sites tessa 1 1,046 01-19-2024, 03:47 AM
Last Post: similarwham
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,141 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,219 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 406 12-07-2023, 03:11 PM
  No Video Out on PBP on all major distros misha64 9 2,800 11-28-2023, 01:41 PM
Last Post: zaius
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 892 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,019 08-21-2023, 09:10 PM
Last Post: vanessadonald
