Manjaro/Plasma Mobile, Lock Screen issues after update
A few days ago, after installing the updates found from the Discover store I rebooted and found that my phone's lock screen will not bring up the on-screen keyboard. I now have to use a physical keyboard to log into the phone.
I just now got a chance to flash the latest nightly of Manjaro/Plasma Mobile from May 2, and the issue still persists. Is this a known issue?
(05-04-2021, 09:24 AM)gamerminstrel Wrote: A few days ago, after installing the updates found from the Discover store I rebooted and found that my phone's lock screen will not bring up the on-screen keyboard. I now have to use a physical keyboard to log into the phone.
I have the same issue... manjaro plasma... after update...
getting around by connecting the power/charger cable connected or as a convergence device with power,USB mouse,keyboard,external display connected.
Mobian (unupdated on a SD card behaves), so does older download of manjaro plasma on SD card(I used jumpdrive to install manjaro plasma on a original phosh pinephone which was functioning well till the last update.
once logged-in, it functions normally(loses GSM modem connection after 10-15mins)
Reproducible problem on every boot... will try to look into it later(busy due to current pandemic calls)... usable as a convergence device at present.
also see https://forum.pine64.org/showthread.php?tid=13690 and https://forum.pine64.org/showthread.php?...ock+screen
flashed Arch linux - phosh...
every thing works like a charm... so far...
much faster... incl firefox(with good scaling too)
  Using too much juice since last update Eugo 20 3,911 03-15-2024, 10:09 AM
Last Post: Eugo
  recent update Uturn 14 2,057 02-13-2024, 01:19 AM
  screen brightness Uturn 1 753 10-09-2023, 04:38 AM
Last Post: Eugo
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,706 10-02-2023, 05:07 AM
Last Post: Uturn
  Manjaro: Settings doesnt open nbh 0 614 09-24-2023, 05:25 PM
Last Post: nbh
  screen brightness locked Uturn 0 695 07-07-2023, 09:38 AM
Last Post: Uturn
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,627 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,656 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 836 04-25-2023, 09:49 AM
Last Post: jakfish
  Latest update Eugo 21 8,635 03-09-2023, 05:27 AM
Last Post: Eugo
