04-23-2021, 01:39 PM
(This post was last modified: 04-27-2021, 03:22 AM by FOSSagent0.)
KDE Plasma Version: 5.21.3
KDE Frameworks Version: 5.80.0
QT Version : 5.15.2
Kernel Version: 5.11.11-1-Manjaro-ARM
OS Type: 64-bit
Hardware : PinePhone Beta Edition
MicroSD: (for music) Samsung Evo 32gb
I got my phone yesterday but I already noticed some bugs and issues, even when updating
1. when I plugged in my phone to charge it with the cable it came in with the screen was showing half of it with the other half black and the menu arrow at the middle of the screen.
2. Terminal did not allow me to close it or minimize the input.
3. Terminal top input where tab, alt etc. was not working, no inputs were working when pressed but the other part where the keys are was working.
4. SD card does not mount automatically, even trying the terminal prompt was not working. I ended up using gnome disks to format and mount it but wierd thing is I still don't see it or can interact with it via the terminal command "sudo mount /dev/mmcblk0p1" ( I just want to use it for my music)
5.Sometimes the screen goes into a half display mode with the bottom half black.
6. Sometimes the error "Modem (quectelqmi_0) IP configuration was unavailable" appears, though that might be due to the T-mobile celluar in the southern California area.
7. When calling there was no options to change output to speaker until after the person picked up on the other end. I made a 2nd brief call but it sounded like one of my calls failed and went mute. (Maybe cellular bandwidth frequency used by T-Mobile in the unincorporated areas of Los Angeles)
8.My alarm clock did not sound until I picked up the phone and clicked the power button.
9. The updating process wasn't exactly smooth, it seemed like it was acting up a bit.
Is there a github/Gitlab for Manjaro Plasma OS? Or is this forum appropriate to post bugs assuming the devs check the forums here out? I went to the Manjaro forums and did not see much for the Pinephone. I do wish there was some kind of getting started and documentation because I was not familiar with this OS or the apps at all coming from one have used UBports before. As or my Sd card any help with that?
I had less then a day with it but maybe I can update some of the issues I have seen so far.
update: 10. I notice that with the WIFi on it consumes the battery quick and within the workday it gets depleted to around 20% on a full charge.
11. Opening the address book and trying to text brings me to a white screen with the following "Device to send a SMS with:" without a number or anything, its a bit weird is that it does not work right.
12. I hooked up my phone to my linux pc via a usb c cable and it's not connecting and allowing me to at least see my images.
QT Version : 5.15.2
OS Type: 64-bit
