RP64 Won't Boot After Power Down
(04-08-2023, 06:56 AM)tizbac Wrote: I'm using a 555 timer pulling down power button for 1 sec every about 3 secs, seems to work for now, 555 is disabled when 3v3 comes up
@tizbac
can you share some details about how you set that up.    I mean which pins of 555 to which pins on RP64.  How to enable that 1sec every 3 with disable on 3.3V.  Any circuits elements you had to add acheive that (resistors, transistors, caps etc.)
https://www.instructables.com/555-Timer/
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,064 04-01-2024, 10:24 PM
Last Post: nano2
  No audio on HDMI after u-boot upgrade xlx 2 1,930 11-28-2023, 01:03 PM
  NAS Setup: Hdds PSU external power option Robotik 1 1,733 07-18-2022, 10:10 PM
Last Post: zer0sig
  NAS case HDD power cable failure (buck failure) ashleymills 1 1,918 04-01-2022, 11:25 AM
Last Post: ashleymills
  Power In Via DC Out actionhank 0 1,306 01-28-2022, 09:45 AM
Last Post: actionhank
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 3,522 11-27-2021, 11:38 PM
Last Post: Cerberus
  RP64 TV box case with wifi Wizzard 2 3,304 03-10-2021, 12:23 AM
Last Post: Wizzard
  Carte PCIe bloquant le démarrage du Noyau / PCIe card blocking Kernel boot dml-pc 4 5,019 02-17-2021, 11:35 AM
Last Post: dml-pc
  How to add an external power button? foresto 6 9,133 02-05-2021, 10:38 PM
Last Post: foresto
  Won't boot with SATA card rjzak 4 5,774 01-09-2021, 05:56 PM
Last Post: kuleszdl
