"script not found! please use a new version image"
Hi everyone,
I received my Pine A64 2G+ and I was exicted to test it; but I even do not success to flash any OS.
the system:
- microSD, samsung 32Go, class 10, with an adapter (but try several), and set the adapter either on the laptop SD reader or using an external USB SD reader
- I downloaded : remix for 32Go, remix for 16Go, android5.1.1 for 32Go and android 5.1.1 for 16 Go
- zip file were decompress using winrar
-installation via Phoenixcard 3.1  (I tested the lower version)
the problem: after clicking on "Img File" and selecting the image (of course the decompress and not the zip) the soft send me the error dialog box "script not found! please use a new version image".
to check the image I launch Win32 disk manager which return me the error "not enough space: blabla"
I can not beleive the 4 OS images I tested were/are not working;
What do you think I did wrong?
thanks
Ludovic
(06-11-2016, 02:54 PM)Ludovic Wrote: Hi everyone,
the system:
thanks
Ludovic
Please see this thread.
RemixOS image for PhoenixCard:
http://files.pine64.org/os/remix/remix-v...ixCard.zip
Android image for PhoenixCard:
http://files.pine64.org/os/android/andro...ixCard.zip
the system:
thanks
Ludovic
Hi Ghost,
I feel dumm, I missed this thread. I'll try and answer back.
thank
L.
the system:
thanks
Ludovic
Hi Ghost,
thank
L.
that's works for the Android image, but I got the message "card preprocess failed" for remixOs! 1251"
but at the works also for Remix Os, the error was coming from my internal card reader which unplugged virtually the microsd
@Ludovic: yes, a USB SD card reader is preferable to internal reader, I think.
Android 5.1.1 Image (LCD Panel Video Output) Release 20160603 Phoenix Card image is not working.
(06-13-2016, 06:07 AM)octopus Wrote: Android 5.1.1 Image (LCD Panel Video Output) Release 20160603 Phoenix Card image is not working.
Are you getting a script not found error? That is what this thread is about.
Yep.
Work around is to use Win32DiskImager.
(06-14-2016, 06:09 AM)octopus Wrote: Yep.
It is not a workaround, exactly. There are images meant for Win32DiskImager (or DD) and there are images meant for PhoenixCard. Images meant for one will not work with the other. If you are getting a script not found error when attempting to burn an image with PhoenixCard, it is because you are trying to burn an image that is meant for Win32DiskImager (or DD).
This is a useful thread. I used Win32Diskimager (because I was used to it on Raspberry Pi) to create a Debian Image on a 16GB card, which worked and could be resized to fill the card. I then tried Android. When I loaded a 16 GB image on a SanDisk Ultra card Win32DiskImager said it was too large (by about 100K) and would not play. Same happened with another card. I then tried Phoenix card and once I found out about the "script not found" bit I used it to burn the Phoenix file and was pleased to find a working Android system which used all the card space
  I found ADB debugging method via USB(OTG) Port spbrain 1 6,824 04-23-2018, 01:49 AM
Last Post: yasser.moj
  Wiki version of Android 7.1 not working with touchscreen abba2566 3 8,834 02-28-2018, 08:02 AM
Last Post: wezzjm
  Reducing Android Image download size. KPhillisJr 4 13,161 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 9,506 07-18-2017, 08:49 AM
Last Post: eclay
  Android 6.0.1 (LCD Panel version) reboot problems Maxim0n 3 8,219 06-26-2017, 07:21 AM
Last Post: pfeerick
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 35,848 05-05-2017, 01:50 AM
Last Post: Quezbeme
  android image & sd card size problems tomarneson 11 27,761 01-24-2017, 05:31 AM
Last Post: ayufan
Question Updating Android version symbiatch 1 5,542 12-01-2016, 02:22 PM
Last Post: ayufan
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 37,908 10-29-2016, 04:31 AM
Last Post: joe
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 8,400 10-17-2016, 11:42 AM
Last Post: mathiraj
