Wiki version of Android 7.1 not working with touchscreen
So after a few attempts, I have managed to get my Pine A64 to boot using the LCD touchscreen, however whilst the touchscreen shows Android fine, it has to be used with a keyboard and mouse as the touch part doesn't seem to be working.
I have everything working with Android 5.1.1 LCD screen version (showing image and touchscreen working) so I think everything hardware wise is working.
The exact version I am running is
http://wiki.pine64.org/index.php/Pine_A6....10-r66.5D (the none TV version)
Can anyone offer any suggestions.
(02-17-2018, 07:57 AM)abba2566 Wrote: So after a few attempts, I have managed to get my Pine A64 to boot using the LCD touchscreen, however whilst the touchscreen shows Android fine, it has to be used with a keyboard and mouse as the touch part doesn't seem to be working.
Just one - try a newer (pre-release) version. As a side-note, I suggest using Android 6.0 instead, as it has much better performance.
As a side note, sometime in March we'll be getting Android 8 for the A64 ... hopefully it will have better performance than 7.1.
Android 8 would be cool too. - I might give that pre-release a go.
The Android 6 image didn't work (I tried flashing it a couple of times), the A64 pretty much turned on then off straight away which is why I've been using the Android 5.1.1 version; which is working fine for now - but obviously android 5 is aging.
Could you perhaps share with me what you did to get the device to even boot? I've been trying the entire day, and all I get is a blank screen. Did you have to modify the uEnv.txt file?
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 381,672 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,146 12-23-2020, 06:11 AM
Last Post: Learnincurve
  3,5mm audio out not working MikkoL 9 14,114 11-22-2020, 06:42 AM
Last Post: Little_Johnny
  Adding an accelerometer to Android modsbyus 11 16,516 11-02-2020, 08:12 PM
  MTP Stopped Working miller08 0 2,358 12-24-2019, 02:42 AM
Last Post: miller08
  Android Things OS dqvsra 2 6,861 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 6,930 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,516 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,289 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 253,697 03-12-2019, 04:53 PM
Last Post: neosapien
