Is there an android tv image out there where I can install netflix?
I've tried to flash the only andorid tv image found in the pine64 etcher tool, which I believe was 7.1, I couldn't find netflix in the app store.  Is there an existing image that will allow me to easily install the netflix?  I'm not sure how to manually install the app from the android tv interface.  If that is my only option does anyone have some steps I could follow?
(07-17-2017, 04:17 PM)eclay Wrote: I've tried to flash the only andorid tv image found in the pine64 etcher tool, which I believe was 7.1, I couldn't find netflix in the app store.  Is there an existing image that will allow me to easily install the netflix?  I'm not sure how to manually install the app from the android tv interface.  If that is my only option does anyone have some steps I could follow?
Netflix on ATV wont work because google does some device checking. So if you want netflix use the regular android image (just get a launcher like TV Launcher).
Thank you. I will give that a try.
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 387,653 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,603 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,763 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,972 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,038 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,603 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,336 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 257,228 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,546 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 104,893 02-10-2019, 07:44 PM
Last Post: mmmarcus
