Android 6.0.1 (LCD Panel version) reboot problems
I have been using Pine A64 2GB version for a year and absolutely love it.
I updated the os from Android 5 to the latest Android 6.0.1 (Android 6.0.1 (LCD Panel Video Output) [20170209]) and i noticed that everything works prefectly as long as you don't  shut the system down.
I have reimaged the memory card and after that everything works just fine until i reboot the system. I do it by holding the power button that is soldered down for ~3 seconds and selecting the shutdown or reboot option. Ether of theese gives the same result, a black screen after initial power on cyckle. Apparantly it's not getting any boot directions from the memory card.
I ran the verify option from the ethcer program and it was successfull and i can see the partitions on the memory card are the same before i initially start the Pine from the memory card and after i shut it down and it does not boot anymore.
I have tried to install this with the Etcher program as well as the new Pine Insaller and i have only used the images provided from wiki.pine64.org or the Pine Installer options.
This did not happen with the Android 5 LCD version and i plan on dowgrading to it to test the boot procedures.
I have changed the memory card to see if the old card had become corrupted. Didn't help.
I'll test this with the non LCD version allso to see if it does the same or not.
Has anyone else noticed this kind of behaviour?
On a new installation of the 6.0.1 lcd image it reboots just fine before making any chages to the system. It seems to be that when accessing the corrupt sd card notification and formating the card to internal storage changes this behaviour.
I'm reimiging right now to test this.
If this is the case, i'm sorry for opening a new thread as the root problem is already discussed in another topic conserning this Android 6.x image and the corrupt memory card notification.
I can now confirm that the reboot issues are caused by the reformatting of the memory card in Android.
(06-26-2017, 01:28 AM)Maxim0n Wrote: I can now confirm that the reboot issues are caused by the reformatting of the memory card in Android.
If you feel this thread was started in error, as you're the OP you will be able delete your first post and remove the thread yourself if you wish Wink
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 381,954 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,180 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,534 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,872 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 6,940 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,525 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,292 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 253,925 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,496 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 103,820 02-10-2019, 07:44 PM
Last Post: mmmarcus
