Anyone have a microphone working on a Pinebook Pro?
I recently learned that i cannot record with a built in microphone. Is this a common issue or does anyone have microphone working on Pinebook Pro?
(02-12-2021, 06:46 AM)Rachel Stone Wrote: I recently learned that i cannot record with a built in microphone. Is this a common issue or does anyone have microphone working on Pinebook Pro?
You are in the wrong section. This area is for the PinePhone. Might want to move this to the Pinebook Pro section.
View my projects at: https://gitlab.com/users/The3DmaN/projects or at the3dman.gitlab.io you can also find me on Matrix in many of the Pine related channels.
@The3DmaN Thread moved.
@Rachel Stone You might want to check the privacy switch for the microphone:
Wiki - Pinebook Pro - Privacy Switches
Arwen Evenstar
Princess of Rivendale
The keyboard firmware really ought to expose these switches over USB. They can be read only. That way it can show up that there microphone is disabled via privacy switch, instead of just mysteriously not working.
And put something on the keyboard markings about the functionality!
@xyzzy I made the suggestion to Jack for his keyboard firmware;
https://github.com/jackhumbert/pinebook-.../issues/10
It's not implemented, yet?.
Arwen Evenstar
Exporting that information would be neat, which could even be done through another, separate USB endpoint, but I think that the reverse engineering of the keyboard firmware requires a lot more work before something like that could be done.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 540 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 341 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 282 02-17-2024, 07:06 PM
  New Working nVME gilwood 0 224 02-12-2024, 08:46 AM
Last Post: gilwood
  Pinebook Pro charging issues tomekdev 1 619 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,086 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,215 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,014 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,420 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 136,114 11-30-2022, 04:28 PM
