Changeing boot animation on Manjaro
Question
Hi everyone!
I would like to change the boot animation on Manjaro.
I installed "bootsplash-viewer" and "bootsplash-packer".
I used a script found on GitHub to create a new bootsplash animation.
I manually copied the created file to "/usr/lib/firmware/bootsplash-themes/custom/bootsplash" and I edited my "extlinux.conf" file to point there but it doesn't work.
Is there anything I forgot to do?
The animation works when using "bootsplah-viewer" to see it.
Thanks!
I'd take a look at plymouth conf and scripts too
Thanks!
Looks like I had to create a install hook and it to mkinitcpio.conf and rebuild the initramfs file.
It works now.
  Manjaro Sway Theme Broken Eighty8 1 330 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,803 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 382 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,235 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,325 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 451 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,331 11-23-2023, 07:37 AM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 957 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,058 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,022 08-21-2023, 09:08 PM
