Modem scripts replaced by eg25-manager by apt-get dist-upgrade
Today I ran apt-get update && apt-get dist-upgrade and noticed the following in the output:
Selecting previously unselected package eg25-manager.
dpkg: considering removing pinephone-modem-scripts in favour of eg25-manager ...
dpkg: yes, will remove pinephone-modem-scripts in favour of eg25-manager
Unpacking eg25-manager (0.1.1-1) ...
Setting up eg25-manager (0.1.1-1) ...
Created symlink /etc/systemd/system/multi-user.target.wants/eg25-manager.service → /lib/systemd/system/eg25-manager.service.
Is this something that is supposed to happen? After rebooting the phone, modem exhibited the same behavior as before - after about 20-30 seconds a 3G signal is indicated, about 10 or 15  minutes later it switches over to 4G. A test call worked OK.
Sometimes reading the source code of both can solve a lot of questions.
https://gitlab.com/mobian1/devices/pinep...em-scripts
https://gitlab.com/mobian1/devices/eg25-manager
Looking at the programming/scripting languages used and how the code itself looks like, my guess is that pinephone-modem-scripts was just a simple script to get around the propertary driver, while eg25-manager is the actual open source replacement.
It happens sometimes within the Linux community when there are only propertary drivers for certain hardware, workarounds or official drivers are being shipped until there's an open source version to replace that.
Basically if it's all working fine (or better), then there's nothing really to be worried about.
Edit:
Here's a more accurate answer:
https://forum.pine64.org/showthread.php?tid=12511
母語は日本語ですが、英語も喋れます(ry
Thanks, I figured it was something like that, just wanted to make sure. Since most of what I want to use the Pinephone for is working it's easy to forget that the software is still alpha and likely to experience major changes.
  Mobian boot failed with zstd message after upgrade. Mahgue 0 666 09-01-2023, 11:29 AM
Last Post: Mahgue
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 2,990 06-06-2023, 06:36 AM
Last Post: freelectro
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,292 03-01-2023, 04:45 PM
Last Post: anonymous
  ModemManager debug mode? (Needed to flash modem) calinb 1 1,265 02-27-2023, 04:18 PM
Last Post: calinb
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 1,036 01-04-2023, 06:46 PM
Last Post: 3x5co
  Receive MMS fails after Nov 27 upgrade treebeard 17 6,267 12-12-2022, 05:09 AM
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 4,520 11-28-2022, 03:30 PM
  need help with downgradin network-manager Ferriah 0 671 11-07-2022, 04:51 PM
Last Post: Ferriah
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,234 09-30-2022, 08:53 PM
Last Post: treebeard
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 5,006 09-23-2022, 05:15 AM
