ModemManager debug mode? (Needed to flash modem)
After replacing my Pinephone's sideboard again (dead microphone for the 2nd time) and the coax cable, my Pinephone can no longer connect to the cellular network (US Mobile T-Mobile MVNO). While I was waiting for parts, I successfully used the SIM card in my old rooted Moto G4 phone while I waited for the parts to arrive.
I can no longer connect to the cellular network. No calls. No SMS. No Internet. Signal strength bars are normal, network is scanned but it will not register. Using ModemManager GUI, it briefly says  "Connecting to US Mobile (Success)" but then vanishes. The symptoms are as described here:
https://forum.pine64.org/showthread.php?...ug+mode%22
My wife's Pinephone still works on the same network, but I don't dare swap her SIM card out and try it! Dodgy
So after trying all the stuff in the thread above, I'm ready to flash my modem again (now running . Unfortunately, looks like I now need to activate "debug" mode--either than or boot an older OS from back when my experimental phone was not "secure" or protected from being repaired  Sad .
error: command failed: 'GDBus.Error:org.freedesktop.ModemManager1.Error.Core.Unauthorized: Cannot send AT command to modem: operation only allowed in debug mode'
I run Mobian. How do I enter debug mode with ModemManager / mmcli so I can use AT commands like I did when I flashed the modem 1-1/2 years ago? If I can't figure out how to use the new ModemManager "debug" mode, I still have one of Megi's multi-boot SD cards and it looks like it still works (I'm running 01.003.01.003):
$ mmcli -m any --command='AT+QGMR'
response: 'EG25GGBR07A08M2G_01.003.01.003'
Thanks for the debug mode secret key or any other advice, including your favorite modem firmware these days. (https://github.com/the-modem-distro/pine.../tag/0.7.3 ???)
Or maybe I should try 30.006.30.006 first.
Update:
I booted Megi's multi-boot to an old rev. of Mobian and updated my modem firmware:
response: 'EG25GGBR07A08M2G_30.006.30.006'
So I guess it worked, but the phone still doesn't work. Guess I'll have to explore and research various settings to set and change.
  Help needed to understand versioning jojuma 3 136 Yesterday, 09:29 AM
Last Post: jojuma
  unofficial kali linux for pinephone help needed pinesmell 5 3,648 01-08-2024, 02:50 PM
Last Post: ERPlegend
  What actions needed to keep on mobian testing user641 3 1,839 09-05-2023, 06:44 AM
  [Megapixels] Flash strobe, pictures viewer and MPCamera error 22 freelectro 1 1,124 08-30-2023, 03:59 AM
Last Post: karensather
  Chatty does not work after suspend mode user641 4 1,947 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 2,837 06-06-2023, 06:36 AM
Last Post: freelectro
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 4,826 09-23-2022, 05:15 AM
  spontaneous reboots in jumpdrive mode flynx 0 644 08-23-2022, 03:48 PM
Last Post: flynx
  Dark Mode biketool 3 2,420 03-17-2022, 06:55 PM
Last Post: jurop88
  Airplane mode Barugon 3 2,903 02-09-2022, 04:04 PM
Last Post: treebeard
