Airplane mode
Anyone know if there's a way to just permanently disable "airplane mode"? If I turn off bluetooth and wifi, it goes into "airplane mode" and also turns off the cell radio. This is really infuriating. Airplane mode is supposed to be a convenient way to turn off all the radios, not a reaction to turning off a couple radios.
(10-16-2021, 03:56 PM)Barugon Wrote: Anyone know if there's a way to just permanently disable "airplane mode"? If I turn off bluetooth and wifi, it goes into "airplane mode" and also turns off the cell radio. This is really infuriating. Airplane mode is supposed to be a convenient way to turn off all the radios, not a reaction to turning off a couple radios.
I'd like to bump that question back to attention - because the Aeroplane Mode is driving me mad.
It seems, the last update of gnome-settings-daemon to v41.0-4 fixed that problem, finally!
Disabling Wifi and Bluetooth is not activating the Aeroplane mode. Nice!
I'm with you - it's time to just eliminate the concept of "airplane mode".  It's easy enough to toggle services on or off as desired.
  Chatty does not work after suspend mode user641 4 1,948 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  ModemManager debug mode? (Needed to flash modem) calinb 1 1,212 02-27-2023, 04:18 PM
Last Post: calinb
  spontaneous reboots in jumpdrive mode flynx 0 644 08-23-2022, 03:48 PM
Last Post: flynx
  Dark Mode biketool 3 2,421 03-17-2022, 06:55 PM
Last Post: jurop88
  Mobile network mode setting not saved Zebulon Walton 3 3,072 12-05-2021, 12:12 AM
Last Post: bcnaz
  Seems like Phosh is in downgrade mode... ryo 17 16,248 06-01-2021, 06:22 PM
Last Post: ryo
