Pinebook Pro refuses to boot from eMMC
#21
> Does the green power light go on at all? I believe it's controlled directly by the pmic
No, not controlled by pmic
If there is no uboot, none of the top leds will light (and you will have no boot)
Nearly always uboot turns a led on*, one (and only one) distro lights late (~13s),
?when kernel loads? (*unless the uboot is "bad")
Since my emmc uboot area is blanked, I get to see all the wonderful uboots out there </s>
#22
(12-12-2020, 01:37 PM)KC9UDX Wrote: Good point.  Do remove the eMMC.
If you've never done this, it isn't obvious, but you just pull it straight up to remove it.
I should mention something else that isn't obvious: all the boot code (including U-boot) exists on the boot device.
If you have boot code on the SPI F-ROM, that runs at startup.
Else, if you have boot code on the eMMC, and it's enabled, that runs at startup.
Else if you have boot code on the micro SD card, that runs.
So unless there's something on the SPI F-ROM (very unlikely), as long as the eMMC can run, a corrupt U-Boot on there will prevent you booting any other way.
Thanks, both to yourself and to @wdt. I've fully charged the computer via USB-C - i.e. until the red light went out - and then removed eMMC.
After that, I've attempted to boot from all of my four different MicroSD cards again, still without any flicker of light from the LEDs on the computer. Before my issue, lights went on when I held the power button for about a second. Now, nothing happens. I've yet again checked all cables but can find nothing that's disconnected or any kind of soldering that seems to be broken.
I also attempted to attach eMMC back and tried the hardware switches in combination. The computer battery is charged, but nothing happens when I try to turn it on, regardless of MicroSD card or image (that's previously worked to boot from).
At this point, I wish there were somewhere I could send the computer for repairs. I don't want to get blindsided by any old repairs page. If you happen to know one online or, preferably, one in Sweden (where I live), I'd very much appreciate a word about it.
Once again, thank you all so much for helping me. I'm happy for all the help, kindness, and wisdom that you've all imparted on me, and if I could thank you all in the flesh, I would.
(12-12-2020, 02:46 PM)xyzzy Wrote: Does the green power light go on at all?  I believe it's controlled directly by the pmic so it should turn green even if the CPU doesn't boot if there is enough power from the battery.
Thanks, but it won't go on; No lights go on whatsoever, apart from the red battery light when I'm charging it (except for when it's fully charged, at which point the light goes out).
#23
OK, button push & no led
You already know to push 1-2 sec, not a quick stab
do, in order
Hard power off,, ~7-8 s, then 1 s start
no led? then
Hard reset,, 20-25s, then 1s start
no led? try another card
preferably with emmc removed, or at least disabled, but better removed
And, you know charging is working OK, well at least as good as it gets
Explanation: AFAIK, since pbp has a battery, a "bad" uboot can persist, even when card is gone
Note which specific card/distro does this (hard lock), let us know, then wipe it, never use that specific distro again
#24
It might be worthwhile to disconnect the battery and leave it for a few hours. (Don't plug in a charging cable!)
I wonder if you have a multimeter and could test the reset switch to make sure it's not stuck closed.
  Pinebook Pro Initial Impressions kunger 443 588,171 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,288 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 395 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 297 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 287 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 222 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 671 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 735 02-01-2024, 11:35 AM
Last Post: tomekdev
  uboot wont boot to SD card after upgrade jbradley419 7 830 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 290 01-16-2024, 09:17 AM
Last Post: jbradley419
