PinePhone OS & Malfunction
Please, have you any way to install mobian? I'm used to install Debian from ISO CD, for this I use a sofware to make iso DVD and than I boot from that. How can I do this with the phone from USB pen? Is it possible?
Thanks, Regards
(12-12-2020, 02:43 AM)tommaso Wrote: Please, have you any way to install mobian? I'm used to install Debian from ISO CD, for this I use a sofware to make iso DVD and than I boot from that. How can I do this with the phone from USB pen? Is it possible?
Thanks, Regards
https://wiki.pine64.org/index.php/Main_Page
You need to flash a system image to sdcard, or you need to flash jumpdrive to a sdcard and then the internal memory will show up as a storage device on USB.
https://mobian-project.org/
  systemic issue pinephone penguins_rule 3 429 04-02-2024, 11:52 AM
  link for supported pinephone os manjharo et all penguins_rule 2 247 03-19-2024, 10:36 AM
Last Post: penguins_rule
  new PinePhone upgrade issue WhiteHexagon 5 1,811 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 2,548 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 7,512 02-04-2023, 08:35 PM
Last Post: Westslope
  Pinephone craches after each call neithan76 2 1,628 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,499 07-28-2022, 12:40 PM
Last Post: johaennessen
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,082 05-09-2022, 08:29 AM
Last Post: ragreenburg
  "Emergency" terminal on pinephone (with default setup) altulke 5 2,696 05-03-2022, 12:42 PM
Last Post: altulke
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 1,902 04-07-2022, 06:02 AM
Last Post: danimations
