2.4 GHz WiFi bandwidth reduced 50% when Bluetooth enabled
Hi all,
This is not a really serious issue, not sure if something can be done in future revisions or not, so this is just in case.
When doing some tests with the maximal WiFi bandwidth (iperf, wget, aria2c etc), on a 40 MHz access point, it's about 100 Mbps if bluetooth firmware is not noaded (to find a way to disable bluetooth chip while keeping WiFi enabled, I removed the rtl8723cs_xx*.bin from initrd.img)
However, if the bluetooth chip is working (firmware loaded), even if set to "disabled", the Wifi bandwidth is capped to 50 Mbps (even when changing WiFi access point frequency from 1 to 13)
As bluetooth and WiFi are both operating at the same frequency range, this is not completely surprising, however I already used devices on which the difference isn't as much.
And... I guess that's all I have to tell about this Tongue didn't played a lot with the 4G modem, I have a spot in the forests where 1 out of 3 panels of the operator's antenna is directed to nowhere in the forest : this is the best 4G bandwidth testing point ever. I'll probably check it out soon with the pinephone
Keep up the great work!
PS : Using "UBports Community Edition" model, which is supposed to be 1.2
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 542 02-17-2024, 04:15 PM
Last Post: vortex
  bluetooth wifi bugs aular 6 1,512 08-27-2023, 07:53 AM
Last Post: aular
Question bluetooth speakers and pinephone pro Supervisor 2 1,261 01-30-2023, 09:21 AM
Last Post: Supervisor
  No wifi/bluetooth on multiple OS's Xxancap15 1 1,130 10-28-2022, 12:10 PM
Last Post: fxc
  Wifi no scan results - Bluetooth adapter not available emsyr 1 1,405 08-29-2022, 02:46 PM
Last Post: emsyr
  Why not Atheros ath9k_htc for wifi? altulke 13 6,679 08-11-2022, 01:01 PM
Last Post: auanta
  Did i break my wifi with the keyboard? captchasolver 5 3,191 02-10-2022, 03:39 PM
Last Post: pothos
  Wifi doesn't respond jmlich 6 4,186 02-04-2022, 06:50 PM
Last Post: bcnaz
  Suddenly WiFi signal strength is poor cinix 4 3,522 09-26-2021, 04:19 PM
Last Post: cinix
  Wifi/BT interface not detected aithal 17 14,807 05-30-2021, 11:10 AM
Last Post: Krasimir
