No wifi/bluetooth on multiple OS's
I have been unable to get the hardware to detect the module since march, possibly could it be the firmware or the board bad? I have a 3gb Convergence model
(10-27-2022, 02:12 PM)Xxancap15 Wrote: I have been unable to get the hardware to detect the module since march, possibly could it be the firmware or the board bad? I have a 3gb Convergence model
If the privacy switch isn't turning the chip off it is likely an hardware issue. The component is directly connected to the battery, a power issue (such as over-voltage typically with non-original batteries in combination with external chargers) can kill the chip. It requires a replacement of the mainboard. I would suggest trying to open a ticket under https://support.pine64.org.
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 491 02-17-2024, 04:15 PM
Last Post: vortex
  bluetooth wifi bugs aular 6 1,436 08-27-2023, 07:53 AM
Last Post: aular
Question bluetooth speakers and pinephone pro Supervisor 2 1,231 01-30-2023, 09:21 AM
Last Post: Supervisor
  Wifi no scan results - Bluetooth adapter not available emsyr 1 1,372 08-29-2022, 02:46 PM
Last Post: emsyr
  Why not Atheros ath9k_htc for wifi? altulke 13 6,578 08-11-2022, 01:01 PM
Last Post: auanta
  Did i break my wifi with the keyboard? captchasolver 5 3,134 02-10-2022, 03:39 PM
Last Post: pothos
  Wifi doesn't respond jmlich 6 4,137 02-04-2022, 06:50 PM
Last Post: bcnaz
  Suddenly WiFi signal strength is poor cinix 4 3,485 09-26-2021, 04:19 PM
Last Post: cinix
  Wifi/BT interface not detected aithal 17 14,666 05-30-2021, 11:10 AM
Last Post: Krasimir
  WIFI not available after anx7688 update failure frimmel 21 19,332 05-11-2021, 02:45 AM
Last Post: frimmel
