We need more power, Scotty!
I've got the power adapter plugged in, but the battery still heads toward zero.
Admittedly, I'm compiling Haskell, so it's not a typical workload.
But still, it'd be nice to power up enough to keep from going to sleep mid-compile.
Any recommendations? I've already fiddled with NVMe settings and turned the brightness down. Can the PBP accept more power from an after-market adapter?
Not without modification.
To get around the power/battery issue, you can bypass the battery thing entirely. If you look at the schematics of the PBP, you can see that you can disconnect the battery and power it directly from the barrel or usb c connection. It was a pretty straightforward process and easy to do. Just make sure you do disconnect the battery as there are warnings that you will fry it. I've been operating my PBP without the battery connected and has been running great. I did have a few shutoffs (2), but being how everything involved with the PBP is in a beta state from hardware and software, I don't know if it was power or software related and really don't have the time to investigate the cause. I don't like working and have to concern myself with battery percentages to keep it from shutting down. Hopefully, this issue gets addressed in a future iteration.
I never really had this problem. Then I tried Manjaro KDE again, and the battery started going down.
I'd been using a very light-colored theme in Mate, with black text on a white background. When the default theme is murky green text on a moody grey background, the user turns the backlight way up, and then most of that energy is lost heating the monitor.
It's not like a CRT where the electron gun only excites the phosphors you use, and green text on black is energy efficient, since the human eye is most sensitive to green light. With an LCD, the backlight is on regardless, and the more of the screen that is high-opacity, the more light you're wasting.
Whatever desktop environment you are on, go for the black UI elements & text on a white background option, and then turn the backlight down until it still doesn't hurt your eyes, and the power usage should go down.
(Yes, I know you said you turned it down, but you can turn it down more this way. And I never had trouble during long compiles.)
Maybe the CPU governor? It'd slow things down, though.
  Lockable-until-power-cycle persistent storage Melab 0 719 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 836 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 631 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 1,259 02-25-2023, 09:00 PM
Last Post: badguru
Heart Now better battery life or power management? KC9UDX 5 2,292 09-09-2022, 08:13 PM
  Replacement Power Cord recommendation? nathanielwheeler 3 3,313 01-23-2021, 06:43 PM
  power light blinking during charge when pbpro is off Idaho 0 1,812 01-04-2021, 10:53 AM
Last Post: Idaho
  Taming the power switch? ab1jx 4 4,906 11-30-2020, 10:57 PM
Last Post: rimaille
  Power consumption and suspend to ram robt 33 43,062 11-30-2020, 04:32 PM
Exclamation Seemingly lost power permanently now /cry jimsurvak 2 3,087 11-16-2020, 06:22 PM
Last Post: jimsurvak
