How to make the Manjaro Gnome image update
Information
FAIR WARNING: After I followed these steps and then updated Manjaro it failed to boot. Until the image itself is updated, I do not recommend installing this variant of Manjaro!
The current Manjaro Gnome image is very old. Manjaro has changed how it updates, so in order to make it update I ran the below command from this comment (https://forum.manjaro.org/t/all-mirrors-.../123901/17) in the Manjaro forums:
sudo pacman -U http://ftp-osl.osuosl.org/pub/manjaro-arm/repo/stable/core/aarch64/pacman-mirrorlist-20200225-1-any.pkg.tar.xz
and then ran pacman -Syyu after. Unfortuantely, that didn't work, as pacman was making a fuss about the xorgproto package, so after a little googling I ran the command: pacman -Rdd libdmx libxxf86dga, which removed the problematic package and allowed me to update.
Hope this saves somebody some time!
EDIT: So that brought the updates up to April. In order to be fully up to date I had to edit my pacman mirrors file (I copied and pasted this from same Manjaro forum, just further down: https://forum.manjaro.org/t/all-mirrors-.../123901/22)
  1. Edit your
    /etc/pacman.d/mirrorlist
  2. file, so only this line is present:
Server = https://manjaro.moson.eu/arm-stable/$repo/$arch
Nice job! I saw that the image was outdated but I just went the lazy route and installed Gnome/ripped out KDE from the default install - was surprisingly painless.
Apparently sometimes the lazy route is better Smile . After going through all the work to get the Manjaro GNOME image to update it ended up not booting after installing all the updates  Angry . So until the image is updated, I do not recommend installing it.
  Manjaro Sway Theme Broken Eighty8 1 280 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 322 03-01-2024, 06:46 PM
Last Post: Puckla
  Pinebook Pro upgrading from the factory image yamsoup 12 1,577 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,754 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 328 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,141 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,217 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 406 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 891 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,019 08-21-2023, 09:10 PM
Last Post: vanessadonald
