How to flash the emmc when it has Chromium on it?
So I installed Chromium on the internal emmc in my PBP. I'm guessing the U-Boot on it has the emmc in the first boot position. I'm assuming the way to flash something else on it would be to corrupt it so that the PBP boots off SD and then I can flash from a Linux distro on there.
How do I corrupt the emmc using Chromium? In particular, the Linux subsystem won't run.
Or is there a better course of action?
Thanks.
If you flip the emmc switch and have a bootable SD card, I don't see
why you couldn't boot whatever on the card
I would use mrfixit, if you update, uboot is ver2, a worthy dd candidate (if=)
Then flip switch at 2 seconds or unbind/bind
lsblk,,blkid
Personally, I would dd /dev/zero to the first 16M, just to be sure
the mrfixit v2 uboot mentioned (as well as pcm720's uboot) can be written to your emmc with Chromium installed. It pretty easy to do, and there a few scripts to help make it easier.
Hi. Thanks for the responses.
Finally figured out I need to get to crosh, and then to a shell, so I could run dd and put a different u-boot on.
Onward!
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 78,362 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 3,176 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 2,559 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 3,077 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 6,584 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 4,071 01-17-2023, 12:07 PM
Last Post: nfms
  What OS have you recently flashed onto PBP eMMC? jcun4128 6 4,387 11-26-2022, 09:39 AM
  Unable to boot from emmc after flashing it rfm83 3 3,278 11-08-2022, 10:59 PM
Last Post: rfm83
  Pinebook picky about which EMMC will boot flatulent_piney 8 5,884 11-05-2022, 06:03 PM
Last Post: ajtravis
  No boot after Manjaro flash PBcurry 14 10,090 10-03-2022, 08:33 PM
