Arch Linux ARM on the Rock64 V3
I just picked up a Rock64, and wanted to put Arch Linux ARM on it to reuse setup scripts I wrote for another SBC that was already running it.
The instructions didn't work for me -- u-boot failed, I would assume because of the SD changes in the V3 revision. Research made it sound like mainline u-boot should work, but I didn't have any luck with it. master failed with a hang trying to access the SD card, and earlier revisions failed with a "Card did not respond to voltage select!" error.
Armbian did work, and I figured all I needed was really a working u-boot, so I bashed together the u-boot from Armbian with the root filesystem from Arch Linux ARM, and it booted!
I would still love to figure out what I was doing wrong with my u-boot builds (following the instructions from here: https://forum.pine64.org/showthread.php?tid=8174), but it seems like it's worked out. Assuming things don't burst into flames or anything.
For reference, this was the process that worked for me:
It's mostly the same as the basic install instructions: https://archlinuxarm.org/platforms/armv8...hip/rock64
  • In step 1, instead of zeroing out, I ran `dd if=/path/to/Armbian_bionic.img of=/dev/sdb bs=1M count=32`
  • Steps 2-8 were unchanged
  • Step 9 was skipped
  • Steps 10-12 were unchanged
  • Skipped updating u-boot through Arch
Thank you for the heads up!
I also run into the issue, but I think ArchLinuxARM fixed their flashing procedure by providing different files to store in the initial non-partitioned space (now called "rksd_loader.img" and "u-boot.itb", see "https://archlinuxarm.org/platforms/armv8/rockchip/rock64").
I simply stored these files into the SD card as the procedure step (9) says:
dd if=rksd_loader.img of=/dev/mmcblk0 seek=64 conv=notrunc
dd if=u-boot.itb of=/dev/mmcblk0 seek=16384 conv=notrunc
After that the board booted normally and I didn't see any loss of data.
(08-17-2020, 11:17 PM)koutheir Wrote: I also run into the issue, but I think ArchLinuxARM fixed their flashing procedure by providing different files to store in the initial non-partitioned space (now called "rksd_loader.img" and "u-boot.itb", see "https://archlinuxarm.org/platforms/armv8/rockchip/rock64").
Nice! That must be brand new, I don't remember seeing it even a few weeks ago.
I'm now running a self-built uboot after running into the Kernel 5.8 issue mentioned on this board, and it seems to work OK. May switch back to this one if it runs into problems.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 19,121 06-27-2026, 02:43 PM
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 2,191 06-25-2026, 03:16 PM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,295 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,277 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 12,230 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,348 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,538 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,485 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 88,105 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 111,493 09-01-2024, 06:05 AM
