Pinebook pro nearly unusable after using manjaro-arm-installer
Good afternoon everyone, about a month ago I tried using the manjaro-arm-installer script to flash the emmc. This completely bricked my device, no booting from emmc or sd card, not even the green LED power light would come on. Finally got around to opening the thing up and hitting the RESET button. This got booting from the sd card working again, but the performance is absolute garbage. I can get to the manjaro KDE desktop but it will freeze if I try to do anything useful. I'm at my wit's end with this thing, any guidance you can offer would be greatly appreciated, Thank You!
(06-18-2021, 03:34 PM)TheCounselor Wrote: Good afternoon everyone, about a month ago I tried using the manjaro-arm-installer script to flash the emmc. This completely bricked my device, no booting from emmc or sd card, not even the green LED power light would come on. Finally got around to opening the thing up and hitting the RESET button. This got booting from the sd card working again, but the performance is absolute garbage. I can get to the manjaro KDE desktop but it will freeze if I try to do anything useful. I'm at my wit's end with this thing, any guidance you can offer would be greatly appreciated, Thank You!
I find KDE to be heavy on an SD card (arguably, on the eMMc as well), so I prefer Xfce, gnome, i3 or sway, any of these are much better in my experience.
As for not being able to run manjaro from the eMMc, only the SD, installing bsp uboot could do the trick, I have to use it with Manjaro and Arch otherwise it won't boot.
Give Armbian a try.
Cheers,
TRS-80
Protocols, not Platforms
  Pinebook pro won't boot after bootloader installation jwensouls 4 830 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 369 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 2,690 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 752 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 3,875 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 2,253 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 787 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 3,123 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 3,383 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 101,885 12-08-2023, 11:25 PM
