webcam framerate bottleneck on linux?
Hi Folks,
I'm trying to understand the performance of the PBP webcam on linux. Here's a related thread from the hardware forum:
https://forum.pine64.org/showthread.php?tid=11460
The tldr is that `v4l2-ctl --list-formats-ext` makes it look like the camera ought to support 20fps at 1600x1200. And indeed, you can even set the camera to that, using v4l2-ctl or guvcview. But the results are clearly not 20fps. The picture quality (motion is blurred) suggests that the trouble is a long exposure time on the camera, even in bright light conditions. The bottleneck isn't the processing power of the PBP, since you can get perfectly good framerates at comparable resolutions with an external webcam.
Is there a v4l2 guru in the house who might have any idea of what's going on here?
  Can’t login to Linux fnosai 0 2,687 07-27-2025, 12:30 AM
Last Post: fnosai
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 2,732 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 5,866 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Slackware Linux working on PBP vxzero 0 3,418 06-05-2024, 04:30 PM
Last Post: vxzero
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 6,645 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 3,049 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 265,182 05-03-2023, 06:10 AM
Last Post: dachalife
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 3,577 11-28-2022, 05:03 PM
  Webcam not working in Manjaro with Cheese, but works in Armbian petaramesh 1 3,261 09-30-2022, 10:09 AM
Last Post: crazyquark
  Arch Linux ARM root filesystem SKiljan 24 43,713 09-24-2022, 03:11 AM
Last Post: alexandre
