Powerful Pinetime with Linux?
I miss a PineTime which is more powerful and has a Linux operating system. Shouldn t this be feasable? There are already such watches available. The Ticwatch Pro for instance has 1 GB of Ram:
https://www.amazon.de/Ticwatch-Pro-gesch...B082Y2Q1LG
and runs android wear. Linux can run on Android wear:
https://www.reddit.com/r/AndroidWear/com...roid_wear/
but what is missing is an easy to use user interface. Make a real Linux Pinetime which is more powerful. All components are available.
What would you want to do with this watch?
As a small IO system for your phone the Pinetime seems just right.
If you want a powerful wrist computer, I think a wrist strap option for the Pinephone would be a better idea. (For the record: I would definitely want one)
Maybe I'm lacking imagination here, but I don't see much use in a powerful watch sized computer.
To be powerful is not so important, but it would be easier to use. When you search on the web, there are people expecting from the PineTime to be a Linux Smartwatch. I m interested in a open source bike computer or bike sportswatch, since Garmins system is too limited for my purpose:
https://forum.pine64.org/showthread.php?...e+computer
I currently have an Android system on two smartphones. But running the software on a watch would eventually be more stable.
Garmin has the option to create custom workouts on some watches. But these custom workouts are not displayed in Garmin Connect. Also it is not possible to access sensor raw data in an easy way.
The Garmin watches are very stable, but too little open for my purpose. The Pinephone is probably the easiest way to start such a project. But a Linux watch which is as close as possible to the Pinephone would be desirable.
(08-20-2020, 07:59 AM)Peter Gamma Wrote: To be powerful is not so important, but it would be easier to use. When you search on the web, there are people expecting from the PineTime to be a Linux Smartwatch. I m interested in a open source bike computer or bike sportswatch, since Garmins system is too limited for my purpose:
There is an open source operating system for smart watches, AsteroidOS, at https://asteroidos.org/
It is much too resource hungry for the Pinetime I believe.
Hugh
Thanks. I looked at AsteroidOS. But is the project alive? There is not even a forum. Maybe the Pinetime is sufficient for my purpose. I m unhappy with Garmin watches. They are market leaders in the segment of sports watches, and many are happy with those. But they store their sensor data in the .fit file system which need a data scientist to get a clear data structure out of it. And for a real-time stream you need either an Azure Cloud abo or Matlab.
When it is possible to get these components to work on a Pinetime:
then I would be perfectly happy with a Pinetime sports watch.
Daniel Thompson, PineTime developer stated on his youtube channel, that he had no plans to use external BLE sensor with PineTime, but connecting PineTime to BLE peripherals is certainly possible... though it would be a lot of work.
https://www.youtube.com/watch?v=lIo2-djNR48&t=118s
On a Linux platform, it is easier, either on the Pinephone or for instance on an Android watch running Linux.
Or on a real Linux watch from Pine64, which I miss.
(09-06-2020, 10:17 AM)Peter Gamma Wrote: Thanks. I looked at AsteroidOS. But is the project alive? There is not even a forum. Maybe the Pinetime is sufficient for my purpose. I m unhappy with Garmin watches. They are market leaders in the segment of sports watches, and many are happy with those. But they store their sensor data in the .fit file system which need a data scientist to get a clear data structure out of it. And for a real-time stream you need either an Azure Cloud abo or Matlab.
Every time I look at the AsteroidOS web site something has changed so it seems to be alive.  If you go to https://asteroidos.org/community/ and look at the box marked Others it says you can join the community on IRC, Twitter or Github.
Hugh
I ve looked at the options to install Linux on Android for instance for the Tickwatch pro with 1 GB RAM. The Tickwatch is powerful, but how to build a watch interface on Linux?
I m a strong advocate for a PineTime with Linux. The PineTime has an excellent user interface. Can it be ported to a Linux Pinetime watch?
AsteroidOS is a full Linux distribution, I did not realize this and underestimated AsteroidOS:
"AsteroidOS is built upon a rock-solid base system. Qt and QML are used for fast and easy app development. OpenEmbedded provides a full GNU/Linux distribution and libhybris allows easy porting to most Android and Wear OS watches."
asteroidos.org
AsteroidOS is especially alive on Twitter:
https://twitter.com/asteroidos?lang=de
There is wrong information about the PineTime in the web. Here is says "the PineTime is 25 USD Linux smartwatch":
https://www.omgubuntu.co.uk/2019/09/pine...smartwatch
I had somewhere in my mind the information, that the PineTime is a Linux watch, which is a wrong information. Now I know from where it came.
The argument that a Linux smartwatch has to expensive is not true. Here I found the information that the KingWear KW88 which can be bought for about 80 USD on Aliexpress can run Linux AsteroidOS, with the issue that the touch screen needs two fingers to be responsive:
https://github.com/AsteroidOS/asteroid/issues/79
edit: issue is resolved already
  PineTime at FOSDEM jmlich 5 1,059 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 345 01-31-2024, 11:57 AM
Last Post: tynstar
  PineTime and Amazfish on Ubuntu Touch jmlich 1 875 10-14-2023, 04:12 PM
  PineTime is dead!! Markdanni123 12 14,435 09-18-2023, 10:17 PM
Last Post: ccchan234
  PineTime Sleep Tracking any_mouse 12 13,017 07-10-2023, 05:41 PM
Last Post: davidair
  PineTime Dead out of box? henkery 1 1,345 03-12-2023, 04:34 PM
Last Post: henkery
  Pinetime almost dead... only shows Infinitime logo. lightweight 8 7,241 02-11-2023, 09:30 AM
Last Post: alexmitroff
  PineTime beginner MV1791 2 2,333 01-09-2023, 11:52 PM
Last Post: Canyonless
  Struggling to detect Pinetime over bluetooth John45595 0 1,234 11-20-2022, 11:06 PM
Last Post: John45595
  PineTime Dev Kit for sale igor.bljahhin 2 3,339 10-19-2022, 05:34 AM
Last Post: peatord
