I just received my Postmarket Edition of the PinePhone. Got it all setup everything was working great but the wifi stopped working.
When I try to reload the wifi kernel module I'm seeing this error in dmesg. Any insight to what might be going on here?
I did notice in my wifi menu that it said something like "wifi adapter not found" My solution was to tap the switch at the top of the screen to turn Wifi on.
I know this solution won't help everybody; but at first I didn't find the UI to be the clearest so I hope this may help someone.
I let the battery get below 20% on the device and it has been stuck at 16% plugged in for several hours. Based on other posts, the wifi must not be working because of a bad battery. I'm not sure since I don't have a second battery to test that hypothesis.
The wifi chip uses some power directly from the battery, so if the battery level is too low or there's no battery inserted the chip won't start causing this error.
I seem to have same problem. I have 90+% battery and bluetooth seems to work.
