Is it possible to pre-configure wifi and ssh with pmbootstrap?
I am trying to get wifi and ssh working on the image without needing to interact with the phone itself to do it.
last time I tried it (March?) pmbootstrap installed sshd by default for the pinephone, and prompted for adding the public key on the machine you were running it from to the image's authorized_keys. After running pmbootstrap you can always mount the target device partition(s) to make any further changes needed.
WiFi may depend on the desktop you're selecting, so you'll have to check where the one you're using puts config files. /etc/NetworkManager/system-connections/ is probably most likely.
(07-05-2020, 02:53 PM)kelbot Wrote: I am trying to get wifi and ssh working on the image without needing to interact with the phone itself to do it.
After installing using pmbootstrap I've been able to connect to the phone via usb networking.
Once connected via ssh you can use the command nmtui-connect to connect to a wifi.
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 1 1,161 11-06-2022, 06:41 PM
Last Post: Chief
Question No connection to internet without wifi :/ elode 3 2,645 03-16-2022, 04:15 PM
Last Post: bcnaz
  pmbootstrap error lat 2 3,523 12-22-2020, 06:32 PM
Last Post: lat
  Wifi and bluetooth disabled after upgrading to PMOS kernel 5.9.1 aithal 0 2,068 11-09-2020, 01:17 AM
Last Post: aithal
  Wifi not working dbrandon 9 10,692 10-09-2020, 06:37 AM
Last Post: quininer
  pmbootstrap issues IVp 3 5,270 09-24-2020, 02:24 AM
Last Post: Pinethom
Question WiFi looks to be working, but ... vidarr 2 3,426 09-08-2020, 04:21 PM
Last Post: vidarr
  pmbootstrap build large keyboard not usable u20200719 5 7,031 07-25-2020, 02:31 PM
Last Post: u20200719
  pmbootstrap to sdcard Jeb5Blovrueb 34 47,336 07-07-2020, 04:17 AM
Last Post: fernando_c_m
  Install And Configure PostmarketOS With Plasma Mobile dustfinger 4 7,907 06-21-2020, 09:00 AM
Last Post: dustfinger
