Wifi and bluetooth disabled after upgrading to PMOS kernel 5.9.1
I have been using Pinephone UBports edition since August. I have been trying out different OS versions, but always had a stable customized SXMO build of PMOS which I have been using with all basic phone functionalities working.
When I upgraded to kernel 5.9.1 pmos sxmo on another sdcard, the wifi and bluetooth stopped working.
The demsg log is as follows -
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.9.1 (pmos@build) (aarch64-alpine-linux-musl-gcc (Alpine 10.2.0) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #4-postmarketos-allwinner SMP Fri Oct 30 07:37:12 UTC 2020
[    0.000000] Machine model: Pine64 PinePhone (1.2)
[    0.000000] earlycon: uart0 at MMIO32 0x0000000001c28000 (options '')
[    0.000000] printk: bootconsole [uart0] enabled
[    0.000000] cma: Reserved 256 MiB at 0x00000000b0000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xafbcc100-0xafbcdfff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000]   DMA32    [mem 0x0000000080000000-0x00000000bfffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] On node 0 totalpages: 524288
[    0.000000]   DMA zone: 4096 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 262144 pages, LIFO batch:63
[    0.000000]   DMA32 zone: 4096 pages used for memmap
[    0.000000]   DMA32 zone: 262144 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
[    0.000000] pcpu-alloc: s50008 r8192 d31912 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: ARM erratum 843419
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: init=/init.sh rw console=tty0 console=ttyS0,115200 earlycon=uart,mmio32,0x01c28000 panic=10 consoleblank=0 loglevel=1 cma=256M PMOS_NO_OUTPUT_REDIRECT PMOS_FORCE_PARTITION_RESIZE pmos_boot=/dev/mmcblk0p1 pmos_root=/dev/mmcblk0p2
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x7bfff000-0x7ffff000] (64MB)
[    0.000000] Memory: 1709188K/2097152K available (10942K kernel code, 650K rwdata, 4064K rodata, 1792K init, 388K bss, 125820K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x304/0x4cc with crng_init=0
[    0.000000] arch_timer: Enabling global workaround for Allwinner erratum UNKNOWN1
[    0.000000] arch_timer: CPU0: Trapping CNTVCT access
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000456] Console: colour dummy device 80x25
[    0.000470] printk: console [tty0] enabled
[    0.000562] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000571] pid_max: default: 32768 minimum: 301
[    0.000662] LSM: Security Framework initializing
[    0.000739] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.000759] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.002520] rcu: Hierarchical SRCU implementation.
[    0.003148] smp: Bringing up secondary CPUs ...
[    0.004663] Detected VIPT I-cache on CPU1
[    0.004726] arch_timer: CPU1: Trapping CNTVCT access
[    0.004739] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.005705] Detected VIPT I-cache on CPU2
[    0.005736] arch_timer: CPU2: Trapping CNTVCT access
[    0.005744] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.006604] Detected VIPT I-cache on CPU3
[    0.006631] arch_timer: CPU3: Trapping CNTVCT access
[    0.006639] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.006711] smp: Brought up 1 node, 4 CPUs
[    0.006716] SMP: Total of 4 processors activated.
[    0.006721] CPU features: detected: 32-bit EL0 Support
[    0.006727] CPU features: detected: CRC32 instructions
[    0.020620] CPU: All CPU(s) started at EL2
[    0.020645] alternatives: patching kernel code
[    0.022461] devtmpfs: initialized
[    0.030904] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.030929] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.040529] pinctrl core: initialized pinctrl subsystem
[    0.041918] NET: Registered protocol family 16
[    0.043680] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.043744] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.043895] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.044861] thermal_sys: Registered thermal governor 'fair_share'
[    0.044866] thermal_sys: Registered thermal governor 'bang_bang'
[    0.044873] thermal_sys: Registered thermal governor 'step_wise'
[    0.044876] thermal_sys: Registered thermal governor 'power_allocator'
[    0.045640] cpuidle: using governor menu
[    0.045820] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.045931] ASID allocator initialised with 65536 entries
[    0.046089] Serial: AMBA PL011 UART driver
[    0.085528] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.085541] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.085546] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.085551] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.087105] cryptd: max_cpu_qlen set to 1000
[    0.091407] iommu: Default domain type: Translated
[    0.091798] SCSI subsystem initialized
[    0.092148] usbcore: registered new interface driver usbfs
[    0.092209] usbcore: registered new interface driver hub
[    0.092301] usbcore: registered new device driver usb
[    0.093398] mc: Linux media interface: v0.10
[    0.093453] videodev: Linux video capture interface: v2.00
[    0.093775] EDAC MC: Ver: 3.0.0
[    0.095923] clocksource: Switched to clocksource arch_sys_counter
[    0.096177] VFS: Disk quotas dquot_6.6.0
[    0.096241] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.108042] NET: Registered protocol family 2
[    0.108527] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.108566] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.108723] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.109058] TCP: Hash tables configured (established 16384 bind 16384)
[    0.109195] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.109254] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.109435] NET: Registered protocol family 1
[    0.110008] RPC: Registered named UNIX socket transport module.
[    0.110012] RPC: Registered udp transport module.
[    0.110015] RPC: Registered tcp transport module.
[    0.110017] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.110718] Unpacking initramfs...
[    0.183151] Freeing initrd memory: 1420K
[    0.184109] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.188579] Initialise system trusted keyrings
[    0.188775] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[    0.197396] NFS: Registering the id_resolver key type
[    0.197430] Key type id_resolver registered
[    0.197433] Key type id_legacy registered
[    0.197537] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.197753] fuse: init (API version 7.31)
[    0.251203] Key type asymmetric registered
[    0.251211] Asymmetric key parser 'x509' registered
[    0.251269] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.251276] io scheduler mq-deadline registered
[    0.251280] io scheduler kyber registered
[    0.257685] sun50i-a64-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    0.259080] sun50i-a64-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator
[    0.279288] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.292047] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
[    0.292096] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
[    0.292145] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
[    0.292189] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
[    0.292580] lima 1c40000.gpu: bus rate = 200000000
[    0.292587] lima 1c40000.gpu: mod rate = 432000000
[    0.293008] [drm] Initialized lima 1.1.0 20191231 for 1c40000.gpu on minor 0
[    0.303316] loop: module loaded
[    0.303855] zram: Added device: zram0
[    0.305862] libphy: Fixed MDIO Bus: probed
[    0.305874] tun: Universal TUN/TAP device driver, 1.6
[    0.306227] VFIO - User Level meta-driver version: 0.3
[    0.307681] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.307689] ehci-platform: EHCI generic platform driver
[    0.308176] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.308207] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.308345] ehci-platform 1c1a000.usb: irq 20, io mem 0x01c1a000
[    0.323967] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.324794] hub 1-0:1.0: USB hub found
[    0.324838] hub 1-0:1.0: 1 port detected
[    0.325795] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.325834] ohci-platform: OHCI generic platform driver
[    0.326074] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.326095] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.326228] ohci-platform 1c1a400.usb: irq 21, io mem 0x01c1a400
[    0.388681] hub 2-0:1.0: USB hub found
[    0.388723] hub 2-0:1.0: 1 port detected
[    0.390244] usbcore: registered new interface driver usb-storage
[    0.393794] sun6i-rtc 1f00000.rtc: registered as rtc0
[    0.393850] sun6i-rtc 1f00000.rtc: setting system clock to 2020-11-09T05:55:36 UTC (1604901336)
[    0.393857] sun6i-rtc 1f00000.rtc: RTC enabled
[    0.394058] i2c /dev entries driver
[    0.395756] sun8i-di 1e00000.deinterlace: Device registered as /dev/video0
[    0.398611] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
[    0.399324] sdhci: Secure Digital Host Controller Interface driver
[    0.399330] sdhci: Copyright(c) Pierre Ossman
[    0.399472] Synopsys Designware Multimedia Card Interface Driver
[    0.400619] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.402005] ledtrig-cpu: registered to indicate activity on CPUs
[    0.402520] SMCCC: SOC_ID: ARCH_FEATURES(ARCH_SOC_ID) returned error: fffffffffffffffd
[    0.402600] hid: raw HID events driver (C) Jiri Kosina
[    0.403622] usbcore: registered new interface driver usbhid
[    0.403632] usbhid: USB HID core driver
[    0.405495] cedrus 1c0e000.video-codec: Device registered as /dev/video1
[    0.406594] ashmem: initialized
[    0.412375] NET: Registered protocol family 17
[    0.412475] Key type dns_resolver registered
[    0.412912] registered taskstats version 1
[    0.412920] Loading compiled-in X.509 certificates
[    0.430671] sun8i-rotate 1020000.rotate: Device registered as /dev/video2
[    0.435658] sunxi-rsb 1f03400.rsb: RSB running at 4000000 Hz
[    0.436139] axp20x-rsb sunxi-rsb-3a3: AXP20x variant AXP803 found
[    0.438190] input: axp20x-pek as /devices/platform/soc/1f03400.rsb/sunxi-rsb-3a3/axp221-pek/input/input0
[    0.443672] axp20x-adc axp813-adc: DMA mask not set
[    0.446286] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
[    0.452103] axp20x-battery-power-supply axp20x-battery-power-supply: Configuring battery thermal regulation for Pinephone
[    0.454529] axp20x-usb-power-supply axp20x-usb-power-supply: DMA mask not set
[    0.455956] random: fast init done
[    0.456743] dcdc1: supplied by regulator-dummy
[    0.457198] dcdc2: supplied by regulator-dummy
[    0.457478] dcdc4: supplied by regulator-dummy
[    0.457755] dcdc5: supplied by regulator-dummy
[    0.458062] dcdc6: supplied by regulator-dummy
[    0.458329] dc1sw: supplied by regulator-dummy
[    0.458552] aldo1: supplied by regulator-dummy
[    0.458626] dovdd-csi: Bringing 3300000uV into 1800000-1800000uV
[    0.458929] aldo2: supplied by regulator-dummy
[    0.459192] aldo3: supplied by regulator-dummy
[    0.459467] dldo1: supplied by regulator-dummy
[    0.459770] dldo2: supplied by regulator-dummy
[    0.460184] dldo3: supplied by regulator-dummy
[    0.460623] dldo4: supplied by regulator-dummy
[    0.460709] vcc-wifi-io: Bringing 3300000uV into 1800000-1800000uV
[    0.461052] eldo1: supplied by regulator-dummy
[    0.461349] eldo2: supplied by regulator-dummy
[    0.461642] eldo3: supplied by regulator-dummy
[    0.461713] dvdd-1v8-csi: Bringing 700000uV into 1800000-1800000uV
[    0.461995] fldo1: supplied by regulator-dummy
[    0.462291] fldo2: supplied by regulator-dummy
[    0.462589] rtc-ldo: supplied by regulator-dummy
[    0.462868] ldo-io0: supplied by regulator-dummy
[    0.463161] ldo-io1: supplied by regulator-dummy
[    0.463229] vcc-1v8-typec: Bringing 3300000uV into 1800000-1800000uV
[    0.463541] axp20x-rsb sunxi-rsb-3a3: AXP20X driver loaded
[    0.469458] sun50i-a64-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.472047] printk: console [ttyS0] disabled
[    0.472144] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 32, base_baud = 1500000) is a 16550A
[    0.472197] printk: console [ttyS0] enabled
[    0.472201] printk: bootconsole [uart0] disabled
[    0.473972] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 33, base_baud = 1500000) is a 16550A
[    0.474189] serial serial0: tty port ttyS1 registered
[    0.475337] 1c28c00.serial: ttyS2 at MMIO 0x1c28c00 (irq = 34, base_baud = 1500000) is a 16550A
[    0.475519] serial serial1: tty port ttyS2 registered
[    0.481196] modem-power serial1-0: modem power manager ready
[    0.507412] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_ops)
[    0.509266] sun4i-drm display-engine: bound 1200000.mixer (ops sun8i_mixer_ops)
[    0.509793] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[    0.509812] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_ops)
[    0.510036] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops sun4i_tcon_ops)
[    0.510071] sun4i-drm display-engine: bound 1ca0000.dsi (ops sun6i_dsi_ops)
[    0.511413] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
[    0.512092] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
[    0.512593] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops)
[    0.513357] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 1
[    0.513459] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
[    0.514580] ehci-platform 1c1b000.usb: EHCI Host Controller
[    0.514605] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
[    0.514747] ehci-platform 1c1b000.usb: irq 22, io mem 0x01c1b000
[    0.514869] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
[    0.527975] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    0.528781] hub 3-0:1.0: USB hub found
[    0.528821] hub 3-0:1.0: 1 port detected
[    0.530117] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    0.530142] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 4
[    0.530300] ohci-platform 1c1b400.usb: irq 23, io mem 0x01c1b400
[    0.592783] hub 4-0:1.0: USB hub found
[    0.592826] hub 4-0:1.0: 1 port detected
[    0.594175] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator
[    0.595241] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
[    0.595268] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 5
[    0.595374] phy id_det change to device
[    0.596106] hub 5-0:1.0: USB hub found
[    0.596145] hub 5-0:1.0: 1 port detected
[    0.701413] Goodix-TS 1-005d: ID 917S, version: 0200
[    0.704980] Goodix-TS 1-005d: Direct firmware load for goodix_917S_cfg.bin failed with error -2
[    0.709406] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pe not found, using dummy regulator
[    0.717453] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    0.720320] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    0.724934] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    0.727984] input: Goodix Capacitive TouchScreen as /devices/platform/soc/1c2ac00.i2c/i2c-1/1-005d/input/input1
[    0.729721] sunxi-mmc 1c11000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    0.732797] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
[    0.785819] mmc0: new high speed SDHC card at address aaaa
[    0.786660] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[    0.789380]  mmcblk0: p1 p2
[    0.913181] mmc2: new DDR MMC card at address 0001
[    0.914233] mmcblk2: mmc2:0001  14.7 GiB
[    0.914722] mmcblk2boot0: mmc2:0001  partition 1 4.00 MiB
[    0.915206] mmcblk2boot1: mmc2:0001  partition 2 4.00 MiB
[    0.920124]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[    0.942291] Console: switching to colour frame buffer device 90x90
[    0.980374] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device
[    0.980397] sun6i-mipi-dsi 1ca0000.dsi: Attached device xbd599
[    0.980431] panel-sitronix-st7703 1ca0000.dsi.0: [drm:st7703_probe] 720x1440@60 24bpp dsi 4dl - ready
[    0.981594] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    0.983873] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    0.984439] dw-apb-uart 1c28000.serial: forbid DMA for kernel console
[    0.985738] Freeing unused kernel memory: 1792K
[    0.985924] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    0.985933] cfg80211: failed to load regulatory.db
[    1.007999] Run /init as init process
[    1.008002]   with arguments:
[    1.008004]     /init
[    1.008007]     PMOS_NO_OUTPUT_REDIRECT
[    1.008009]     PMOS_FORCE_PARTITION_RESIZE
[    1.008011]   with environment:
[    1.008013]     HOME=/
[    1.008016]     TERM=linux
[    1.008018]     pmos_boot=/dev/mmcblk0p1
[    1.008020]     pmos_root=/dev/mmcblk0p2
[    1.127928] anx7688 1-0028: power enabled
[    1.128776] anx7688 1-0028: Vendor id 0x1f29
[    1.143923] anx7688 1-0028: power disabled
[    1.144226] anx7688 1-0028: plug irq (cd=1)
[    1.144348] anx7688 1-0028: enabling USB BC 1.2 detection
[    1.144396] anx7688 1-0028: setting vbus_in current limit to 500000 mA
[    1.159945] anx7688 1-0028: cable inserted
[    1.199936] anx7688 1-0028: power enabled
[    1.265033] anx7688 1-0028: eeprom0 = 0x03
[    1.265296] anx7688 1-0028: fw loaded after 40 ms
[    1.266694] anx7688 1-0028: OCM firmware loaded (version 0x2312)
[    1.277433] anx7688 1-0028: send pd packet cmd=0 05 00 32 90 01 26 12
[    1.313159] anx7688 1-0028: send pd packet cmd=1 05 01 2c 91 01 26 16
[    1.314837] anx7688 1-0028: send pd packet cmd=2 11 02 00 00 00 ec 00 00 00 00 00 00 00 00 39 00 00 51 77
[    1.317613] anx7688 1-0028: send pd packet cmd=3 05 03 00 00 01 ff f8
[    1.319286] anx7688 1-0028: OCM configuration completed
[    1.320676] anx7688 1-0028: status changed to 0x00
[    1.320687] anx7688 1-0028: cc_status changed to CC1 = SRC.Open CC2 = SRC.Open
[    1.320692] anx7688 1-0028: dp state changed to 0x00
[    1.412776] anx7688 1-0028: cc_status changed to CC1 = SRC.Ra CC2 = SRC.Ra
[    1.615869] using random self ethernet address
[    1.615878] using random host ethernet address
[    1.626825] usb0: HOST MAC 5a:5b:2e:43:59:4c
[    1.626868] usb0: MAC 0e:e7:54:d1:5f:33
[    1.664731] EXT4-fs (mmcblk0p1): mounted filesystem without journal. Opts: (null)
[    3.796147] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.828991] EXT4-fs (mmcblk0p1): warning: mounting unchecked fs, running e2fsck is recommended
[    3.871792] EXT4-fs (mmcblk0p1): mounted filesystem without journal. Opts: (null)
[    3.871849] ext4 filesystem being mounted at /sysroot/boot supports timestamps until 2038 (0x7fffffff)
[    5.728846] device-mapper: table: 253:0: linear: Device lookup failed
[    5.728856] device-mapper: ioctl: error adding target to table
[    5.742333] device-mapper: table: 253:0: linear: Device lookup failed
[    5.742342] device-mapper: ioctl: error adding target to table
[    6.199117] udevd[2015]: starting version 3.2.9
[    6.222950] random: udevd: uninitialized urandom read (16 bytes read)
[    6.224202] random: udevd: uninitialized urandom read (16 bytes read)
[    6.224257] random: udevd: uninitialized urandom read (16 bytes read)
[    6.289950] udevd[2015]: starting eudev-3.2.9
[    6.418497] i2c-gpio i2c-csi: using lines 141 (SDA) and 140 (SCL)
[    6.601725] NET: Registered protocol family 10
[    6.602809] Segment Routing with IPv6
[    6.655172] input: 1c21800.lradc as /devices/platform/soc/1c21800.lradc/input/input2
[    6.775401] input: gpio-vibrator as /devices/platform/vibrator/input/input3
[    6.784933] bt-sco bt-sco-codec: ASoC: sink widget Capture overwritten
[    6.784949] bt-sco bt-sco-codec: ASoC: source widget Playback overwritten
[    6.785058] simple-amplifier audio-amplifier: supply VCC not found, using dummy regulator
[    6.789852] debugfs: File 'Playback' in directory 'dapm' already present!
[    6.789867] debugfs: File 'Capture' in directory 'dapm' already present!
[    6.792114] input: PinePhone Headset Jack as /devices/platform/sound/sound/card0/input4
[    6.816748] iio iio:device3: interrupts on the rising edge
[    6.819492] iio iio:device3: registered magnetometer lis3mdl
[    6.916260] Bluetooth: Core ver 2.22
[    6.916376] NET: Registered protocol family 31
[    6.916380] Bluetooth: HCI device and connection manager initialized
[    6.916410] Bluetooth: HCI socket layer initialized
[    6.916420] Bluetooth: L2CAP socket layer initialized
[    6.916456] Bluetooth: SCO socket layer initialized
[    6.958482] sun6i-csi 1cb0000.csi: creating gc2145 4-003c:0 -> sun6i-csi:0 link
[    6.958495] sun6i-csi 1cb0000.csi: creating ov5640 4-004c:0 -> sun6i-csi:0 link
[    6.966073] Bluetooth: HCI UART driver ver 2.3
[    6.966087] Bluetooth: HCI UART protocol H4 registered
[    6.966177] Bluetooth: HCI UART protocol LL registered
[    6.966249] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    6.967221] dw-apb-uart 1c28400.serial: failed to request DMA
[    6.967418] Bluetooth: HCI UART protocol Broadcom registered
[    7.198951] i2c i2c-2: Added multiplexed i2c bus 5
[    8.279301] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    8.542949] urandom_read: 5 callbacks suppressed
[    8.542958] random: mktemp: uninitialized urandom read (10 bytes read)
[    8.983590] random: dbus-daemon: uninitialized urandom read (12 bytes read)
[    9.363190] modem-power serial1-0: powering up
[    9.628036] modem-power serial1-0: wakeup ok
[   10.744219] random: crng init done
[   12.575842] modem-power serial1-0: status ok
[   12.576228] dw-apb-uart 1c28c00.serial: failed to request DMA
[   22.843466] usb 3-1: new high-speed USB device number 2 using ehci-platform
[   23.081962] usbcore: registered new interface driver cdc_wdm
[   23.091657] usbcore: registered new interface driver option
[   23.091725] usbserial: USB Serial support registered for GSM modem (1-port)
[   23.092091] option 3-1:1.0: GSM modem (1-port) converter detected
[   23.092545] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB0
[   23.092809] option 3-1:1.1: GSM modem (1-port) converter detected
[   23.094234] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB1
[   23.095691] option 3-1:1.2: GSM modem (1-port) converter detected
[   23.098746] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB2
[   23.099017] option 3-1:1.3: GSM modem (1-port) converter detected
[   23.099878] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB3
[   23.111216] qmi_wwan 3-1:1.4: cdc-wdm0: USB WDM device
[   23.112690] qmi_wwan 3-1:1.4 wwan0: register 'qmi_wwan' at usb-1c1b000.usb-1, WWAN/QMI device, c6:bb:e8:65:3c:e6
[   23.112837] usbcore: registered new interface driver qmi_wwan
[   26.581509] modem-power serial1-0: ===================================================
[   26.581525] modem-power serial1-0: Project Name: EG25G
[   26.581534] modem-power serial1-0: Project Rev : EG25GGBR07A08M2G_01.001.10
[   26.581542] modem-power serial1-0: Branch  Name: 9x07_R07_NEW
[   26.581549] modem-power serial1-0: Custom Name : STD
[   26.581557] modem-power serial1-0: Build   Date: 2019-12-03,18:10
[   26.581566] modem-power serial1-0: Version:    SBLR07EG25G01_1:37500: Oct 17 2
[   26.581573] modem-power serial1-0: Version:    TZR07A03: Dec  2 2019
[   26.581582] modem-power serial1-0: Version:    RPMR07A03_1:37500: Dec  2 2019
[   26.581588] modem-power serial1-0: ===================================================
[   26.581597] modem-power serial1-0: Your modem has an outdated firmware. Latest know version is EG25GGBR07A08M2G_01.002.07. Consider updating.
[   26.591356] modem-power serial1-0: ADB KEY is '32251809' (you can use it to unlock ADB access to the modem, see https://xnux.eu/devices/feature/modem-pp.html)
[   27.635294] modem-power serial1-0: QDAI is '1,1,0,1,0,0,1,1'
[   27.647281] modem-power serial1-0: QCFG 'risignaltype' is '"physical"'
[   27.659370] modem-power serial1-0: QCFG 'urc/ri/ring' is '"pulse",1,1000,5000,"off",1'
[   27.675268] modem-power serial1-0: QCFG 'urc/ri/smsincoming' is '"pulse",1,1'
[   27.691291] modem-power serial1-0: QCFG 'urc/ri/other' is '"off",1,1'
[   27.703313] modem-power serial1-0: QCFG 'urc/ri/pin' is 'uart_ri'
[   27.715373] modem-power serial1-0: QCFG 'urc/delay' is '0'
[   27.727336] modem-power serial1-0: QCFG 'sleepind/level' is '0'
[   27.743366] modem-power serial1-0: QCFG 'wakeupin/level' is '0'
[   27.755288] modem-power serial1-0: QCFG 'ApRstLevel' is '1' (changing to '0')
[   27.779290] modem-power serial1-0: QCFG 'ModemRstLevel' is '0'
[   27.791309] modem-power serial1-0: QCFG 'apready' is '0,0,500'
[   27.803274] modem-power serial1-0: QCFG 'airplanecontrol' is '1,0'
[   27.815301] modem-power serial1-0: AT command 'AT+QCFG="fast/poweroff"' returned ERROR
[   27.839310] modem-power serial1-0: powered up in 18476 ms
[   31.715157] vbat-wifi: disabling
[   31.715197] avdd-csi: disabling
[   31.715260] usb-5v: disabling
I see vbat-wifi disabling at the end and rtl8723cs kernel module for wifi doesn't load on turning on the phone or when the phone is rebooted.
ipconfig -a output -
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:4 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:288 (288.0 B)  TX bytes:288 (288.0 B)
usb0      Link encap:Ethernet  HWaddr D6:BC:2F:DA:FA:00
          inet addr:172.16.42.1  Bcast:172.16.255.255  Mask:255.255.0.0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wwan0    Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          POINTOPOINT NOARP MULTICAST  MTU:1500  Metric:1
I have tried different versions of OS and it is same on all. wifi and bluetooth interface is never started on all.
Anyone here encountered this eror? I have tried different options browsing the internet with little, all kinds on help to fix this issue is welcome. Please help!!!
  Bluetooth keyboard paired to PostmarkedOS disconnect Peter Gamma 2 1,518 10-21-2023, 12:32 AM
Last Post: Peter Gamma
  Fresh install pmos+phosh does not boot user641 1 488 10-08-2023, 04:04 AM
Last Post: user641
  Boots To Shell After Dead Battery (PMOS) britelite 0 715 02-17-2023, 02:41 PM
Last Post: britelite
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 1 1,161 11-06-2022, 06:41 PM
Last Post: Chief
  No Application Data PMOS 21.12.1 Captain1ndustry 4 3,865 08-12-2022, 07:42 AM
Last Post: Gon
  pmos/phosh edge update and audio disappears robthebold 9 5,525 07-10-2022, 03:26 AM
Last Post: arkadione
  Bluetooth mouse paired to PinePhone POS always disconnect Peter Gamma 0 980 06-12-2022, 03:03 AM
Question No connection to internet without wifi :/ elode 3 2,642 03-16-2022, 04:15 PM
Last Post: bcnaz
  Application list PMOS-Phosh jmorris 6 6,133 12-04-2021, 02:26 AM
Last Post: Juergen
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 5,700 02-28-2021, 02:20 PM
Last Post: MtnSk8
