Manjaro Arm i3 HELP
Hey guys,
I just got my PBP last night and I flashed the new 128GB emmc with the image. Put it in the PBP, boot up, went through username/pw, locale, etc., It auto reboots.
It just stays in a black screen. So I went to tty1-6 and switch it back to tty7, the login screen is there, but can't move the mouse or type. So i tried to type and then switch back to tty6 and back, tty7 recognizes it. I had to keep switching back and forth back and forth.
Has anyone tested i3 on the new batch of PBP?
I also try to run the i3 via sd, but it does the exact same thing.
any ideas?
(06-18-2020, 04:37 AM)HaxNet Wrote: Hey guys,
any ideas?
See https://forum.manjaro.org/t/pinebook-pin.../133927/10
Basically it was an issue with the console, try to update to latest or reinstall with 20.06 which was released a few days ago.
any ideas?
Thanks, I literally went through a bunch of threads and found the 20.06. I will give it a try and report back.
I used the new release and still the same. I have to keep going back and forth tty6 and tty7 to see any movements
  Manjaro Sway Theme Broken Eighty8 1 410 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,857 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 461 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,343 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,472 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 519 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 1,054 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,090 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,072 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 871 08-18-2023, 02:06 AM
Last Post: juliamenendez
