Pinebook Pro kit without the rockpro
So if I buy rockpro, and then decide to stick it inside pinebook pro, I won't be able to buy battery even if I lied about why, as it only ships to USA, and you can only buy individual parts as replacement. Also there're people that complain that you can't customize emmc storage, and that would hypothetically be one of the ways to do it, buying the chip and emmc separately.
(05-26-2020, 01:03 AM)janat08 Wrote: So if I buy rockpro, and then decide to stick it inside pinebook pro, I won't be able to buy battery even if I lied about why, as it only ships to USA, and you can only buy individual parts as replacement. Also there're people that complain that you can't customize emmc storage, and that would hypothetically be one of the ways to do it, buying the chip and emmc separately.
Not quite sure what you're truing to achieve here... the rockpro64 won't fit inside the pinebook pro... you'd have to remove all the headers, network connector, USB connectors, HDMI, PCIe socket, etc, etc... and then how do you wire up to the display, keyboard, touchpad, etc?
The soc inside pbp, isn't rockpro, and is a custom chip? I suppose it makes little sense to use rockpro inside a laptop, or to sell the laptop soc individually.
I was looking for desktop replacement I could recycle into a laptop.
(05-26-2020, 03:16 AM)janat08 Wrote: The soc inside pbp, isn't rockpro, and is a custom chip? I suppose it makes little sense to use rockpro inside a laptop, or to sell the laptop soc individually.
The SoC in the PBP "is" the same as the RockPro, however, it's been altered significantly to fit within the PBP chassis. The specs are the same, but the form factor of the board is very different. Hope that clears things up a little.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 1,077 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 464 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 410 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 743 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,279 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 133,665 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,291 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,709 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 140,898 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 2,033 10-21-2022, 07:57 AM
Last Post: dachalife
