PyQT5 Manjaro
Hi All, I've been trying to run electrum wallet from python source on the Manjaro image.  Everything fails looking for pyQt5.
This is installed via pacman so not sure why It's not working...
Everything I find online seems to be a dead end so wondered if anyone had any ideas how to get it working?
Not sure if this helps, but PyQt5 requires a full Qt install to work properly.
(01-25-2020, 12:27 AM)metcalsr Wrote: Not sure if this helps, but PyQt5 requires a full Qt install to work properly.
All fixedSmile
Long story short, I just learned never to use pip to install anything.
I also found that when I added additional mirrors to pacman everything seems to be installing properly so might be a combination of the two!
  Manjaro Sway Theme Broken Eighty8 1 438 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,871 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 476 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,385 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,500 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 535 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 1,078 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,104 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,086 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 879 08-18-2023, 02:06 AM
Last Post: juliamenendez
