Linux Mint?
Just got my PBP yesterday.   Could not be happier! It is exactly as described and does everything very well right out of the box!
One, tiny little thing.  Is there a chance of running Linux Mint instead of Debian?  I have recently gotten used to Mint 19.2 and the Cinnamon shell and really like it.  Debian / Mate is certainly not bad, but I love all the extras brought to the table by Mint.  Is anyone working on this?
Thanks!
(11-01-2019, 06:14 AM)ta2025 Wrote: Just got my PBP yesterday.   Could not be happier! It is exactly as described and does everything very well right out of the box!
Thanks!
The short answer is that Mint doesn't produce arm images. Even if they did each arm board needs it's own image because there is no bios on the boards.
Thanks!
If you like Linux mint running Cinnamon (I do too), then there is a chance you'll get a similar experience with Ubuntu + Cinnamon.
can you get that just by installing cinnamon from Synaptic?
Thanks!
Just thought I would ask because its not as easy to find things in this system as people might think.  Also, someone might pop and say "Oh!  I just heard they are releasing Mint for ARM next week.  You never know!
Thanks!
How?  Do just install Cinnamon from Synaptics and it replace Mate as the default desktop?
(11-01-2019, 12:54 PM)ta2025 Wrote: can you get that just by installing cinnamon from Synaptic?
Thanks!
Thanks!
I went ahead and installed the cinnamon files from Synaptics.  How do you actually switch your desktop Enviromnment.  In many other distros like ubuntu and mint, when you login, you have a switch they lets you pick which desktop environment you wish to use for the session.  I cannot find it on this distribution on Debian.
How does one change desktops?
Add option to switch DE to lightdm.
But again, you should install this on Ubuntu rather than Debian.
Thanks!
 NOT CERTAIN :
  But I think I saw a "Mint DE"  at the Debian download website..   ?    (since Mint is based on Ubuntu, which is based on Debian etc...)  ?
Last time I visited the Debian site (earlier this year), they had a cool new set-up, you answer some questions and they put together all the required components.
a few minutes later you just download your requested custom built operating system...
Not sure if that works for arm systems, but it could be very helpful if it does.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(11-03-2019, 08:06 AM)Luke Wrote: Add option to switch DE to lightdm.
Where do I find an Ubuntu image to load onto the PBP?
Here https://forum.pine64.org/showthread.php?tid=8119
I launched Cinnamon on Ubuntu. Unfortunately, only with software rendering mode.
  Slackware Linux working on PBP vxzero 0 66 06-05-2024, 04:30 PM
Last Post: vxzero
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 512 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,707 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 756 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 164,111 05-03-2023, 06:10 AM
Last Post: dachalife
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 1,277 11-28-2022, 05:03 PM
  Arch Linux ARM root filesystem SKiljan 24 21,773 09-24-2022, 03:11 AM
Last Post: alexandre
Information Install Void Linux with near-full-disk encryption dumetrulo 3 3,257 09-05-2022, 12:00 PM
Last Post: petersen77
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 2,508 08-25-2022, 02:15 PM
Last Post: Niko
  Problems installing/ booting a different Linux on PinebookPro v-man 3 3,194 03-22-2022, 06:37 PM
Last Post: pentamassiv
